Studebaker Engine ID help
Discussion in 'The Hokey Ass Message Board' started by white mule, Jan 18, 2014.
  1. I recently bought a 1947 M5 Studebaker Truck. It cam with 2 engines. I am trying to Identify them. Any help would be great.
    First Engine
    SCI8628 Stamped Number under head on front drivers side
    1548965-5 Cast number on left side oil pan rail
    2nd engine
    IN28953 Stamped under head drivers side
    518448-2 Cast on pan rail
    These are flat six engines
  2. Da Tinman
    Da Tinman
  3. nrgwizard
    nrgwizard
    from Minn. uSA
    BTW: not knowing where you're going w/this, it might help to know, or consider, that Studies are well suited to supercharging &/or turbos, w/very little "spl" work. So yah, I agree w/tinman, keep the stude. Plus, very few will actually know what it is... :D .
    Glad to see another Stude being brought back to life.
    Marcus...
  4. aaron_eckhoff
    aaron_eckhoff
    I can get you the info just need to talk to a guy first, he drove the Avanti Bucket List Dream. He just picked up an M16 Truck.
  5. Well I figured it out... First engine is a 1960 170 cube.
    The 2nd engine is the original.... So it looks like I will be mating the original ****** (3 spd floor shift) to the 1960 engine until I can rebuild the 2nd engine. (which looks like it might have already been done) I want NOS speed parts for the original. I am not sure What I will do with this truck. What I do know is it will be all stude.
  6. Bonneville Avanti Dan
    Yes, the SC engine is a 1960 engine only 170 cid and about 80 hp. The other engine is not listed on the engine codes list. Are you sure it is "IN"? there are numbers starting with a "1" but no "I"s.
    Dan
  7. 5brown1
    5brown1
    I believe Studebaker used an "I" as a 1 in their stampings often and possibly always.
