Projects 55 Chevy, early 60's gasser style..
Discussion in 'The Hokey Ass Message Board' started by Crashhead, Jan 12, 2014.
  1. Jay Tyrrell
    Jay Tyrrell
    Totally agree here too. I have read your total post and you have said that you were not sure that you were going to keep the lowering blocks and that you might be changing the springs. I would suggest that you get the suspension set just as you want it (the final product) before you make your radius. Radiusing would be one of the last thing I would do before any paint. Get the weight back on the car and in the car before making the cut. Seen way too many radius jobs that were not thought out and would want to see you go down that road man! Kinda hard to put material back if you screw up and take a little too much! BTW I like your radius tool!
    Jay
  2. Crashhead
    Crashhead
    Thanks alot guys, appreciate it. Well, i do have a vision of how high up i want the wheel opening to be, and i have always loved it when the top of it is parallel to the center of the gas cap..
    That is what i am going for. I am very well aware of the fact that the car will be considerably lower while completeted.
  3. I love the wheel tool tracer thing you made for the rear wheel well arch, what are the details on that?
  4. Crashhead
    Crashhead
    Thanks man. Just made it out of s**** i found in the shop. The center bracket that goes across the rim is adjustable, and can be used with any size rim. Used a old shift linkage from the center rod, and over that goes a piece of square tubing that is adjustable, with a pencil at the end. Very quickly made, and crude but works really good!
  5. Crashhead
    Crashhead
    Radiused the wheel wells yesterday. They are far from done, but merely a start so i can get a overall idea about the stance, and get to work on the trunkfloor..and some standard rust issues...
    Hoping to have the trunk floor and wheeltubs made in a few weeks, time allowing
  6. squirrel
    great progress so far!
  7. enloe
    enloe
    from east , tn.
  8. AHotRod
    AHotRod
    It's quickly taking on "The Look" !
  9. mad mikey
    mad mikey
    Its going to be a BAD G***ER! Nice work so far.
  10. squirrel
    gratuitous artwork
  11. Crashhead
    Crashhead
    That is some great art. Thanks man!
    So, if anyone know of a chromed roll cage for the -55, i'm interested!
  12. squirrel
    build one....
  13. Lancer
    Lancer
    Looking good man, you'll have to drag it down to Eagle Field and I can run you in my 56 Ford once its done!!! What are you doing for a motor, 283/327??
  14. Crashhead
    Crashhead
    Hey man! Yes, we hope to have it down there in May. Would love to race ya, haha!
    Will be running a 350cui...for now ;)
  15. Lancer
    Lancer
    Oct. would be the first we could conceivably run at. I'll be shooting pics and video in May though so hope to see you there.
  16. Butch M
    Butch M
    looking good love those wheels and tires
  17. Jay Tyrrell
    Jay Tyrrell
    Did a good job on the radius! Coming together really nicely!
    Jay
  18. second fiddle
    second fiddle
    Awesome! with the way this thing is taking shape it should be done by....oh' mid Feb!
  19. Crashhead
    Crashhead
    Haha, not really i'm afraid...but around June, July is our goal. Maybe just in time for our 5th annual carshow, http://www.norcalknockout.com/
    Continuing on the trunk floor and brackets for the fuel cell tomorrow
  20. CalGasser
    CalGasser
    I got my 55 running about a year ago and really enjoying her. On the radiused wheel wells, we made mine a tad oval with it a bit taller than wide to allow for ch***is squat. If we drew a radius from the axle center like you did, the distance would be equal around the tire and not enough vertical clearance - if you go taller, then the sides will have too large a gap. As it turned out from a video at Eagle Field, car barely squats so no clearance issues. ;)
  21. Looking good!
    I love me them '55 Chevies!
    Sam
  22. black 62
    black 62
    from arkansas
    if your ch***is works you get separation ,not squat...
  23. squirrel
    ...but if you drive it on the street, you get cut tires
  24. Crashhead
    Crashhead
    Looks good to me man!
  25. CalGasser
    CalGasser
    Understood... if it expands, it still has to compress. What happens when one pulls a wheelie? :confused: Whichever direction, it needs ample clearance for rebound.
    Thank you! ;)
  26. jakedmoe
    jakedmoe
    looks good some great advice on here so far!
  27. Crashhead
    Crashhead
    Started wrestling around with the wheel tubs purchased from Summit. Not the easiest thing on the planet to measure and cut so they'll fit smoothly against the fender. Lots of patience and a weekend later i am at least on the way. Next step will be to make the mounts for both battery and fuel cell.
  28. fleet-master
    fleet-master
    looks like the rear has settled some or have you used the cement bags in the trunk (my personal favourite) to get and maintain ride height?
    I love Tri-5's done this way!! Cool choice in wheels/tyres too btw
  29. 66cayne
    66cayne
    next time try fabbing the wheelwells using cardboard to form patterns. Then transfer the patterns to the sheetmetal. Saves time and sheet metal...
  30. Crashhead
    Crashhead
    Yes, that could have been an option, but this was fairly simple too and worked out just fine. Moving along....
