Technical 32 windshield glass install???
Discussion in 'Traditional Hot Rods' started by marfen, Jan 22, 2014.
  1. marfen
    marfen
    from sask
    What's the best method / materials to use for installing the gl*** in a 32 ford windshield frame that doesn't create a nightmare job when the gl*** needs replacing down the road (hard to keep gl*** crack free up here). any suggestions mucho appreciated.
    chucks32 likes this.
  2. Windshield setting tape.
    It comes in different thicknesses so you need to know the gl*** thickness and the available space in the windshield frame that you will be working with.
    Bob Drake sell it in various thicknesses.
  3. pasadenahotrod
    pasadenahotrod
    from Texas
    Your local gl*** shop with probably mount it in black silicone.
  4. HOTRODPRIMER
    HOTRODPRIMER
    I guess it depends on the shop,the guy that replaced the gl*** in my Deuce windshield frame used the gl*** setting tape but he's been in the business as long as I can remember and worked for a gentleman that was replacing gl*** when Model A's were new. HRP
  5. Old Tin and New Tin
    Old Tin and New Tin
    Use gl*** setting tape if you plan on driving the car and will be replacing the windshield on a regular basis. Steer away from urethane if you want to get it apart cleanly.
  6. hammeredcoupe
    hammeredcoupe
    from Tacoma,WA
    definitely go with the gl*** setting tape. I removed one that been set in urethane or silicone and it was a nightmare.
  7. marfen
    marfen
    from sask
    thanks folks. Gl*** setting tape it will be. I had to deal with black silicon or urethane getting the gl*** out of a spare frame, ****py job.
  8. DICK SPADARO
    DICK SPADARO
    Simplest stuff to use is Black cloth electrical tape sometime called friction tape or black hockey stick tape. Take a razor blade and trim it up done deal. if the gl*** gets cracked or chipped in use it will easily come apart for replace. Urethane's a NO No...
  9. alchemy
    alchemy
    You will probably get leaks around the setting tape though. I used a small bead of urethane as a seal on a '32 windshield that was installed with setting tape. Just a thin bead smoothed out with my finger over the top edge of the tape, and cleaned up a little with lacquer thinner. Works fine (no leaks through it), and should be kinda easy to remove later if neccessary.
  10. HOTRODPRIMER
    HOTRODPRIMER
    I have been very fortunate when it came to using the gl*** setting tape and amazed at how well the new Bob Drake rubber sealed the frame to the body. HRP
