54 mercury manual steering options
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by 54Gabe, Jan 18, 2014.
  1. 54Gabe
    54Gabe
    Manual steering box is shot :mad: in my 54 Mercury , want to up grade to newer steering box. I would like to keep the manual steering setup in my car. What other steering boxes would work in my mercury?
  2. 54monarch
    54monarch
    from Calgary
    This is not an easy swap out. The steering shaft is pressed into the steering box. You will either have to cut the old shaft off or have it removed at a shop.
    I am most of the way through a power steering upgrade using an Isuzu box and an adapter plate. I will be using an aftermarket steering column.
    I have a big block in the car and parking has become near impossible.
    If you are married to manual steering you would be best off having your stock box rebuilt.
    Vic
  3. the-stig
    the-stig
    Welcome from So Cal. Check out the 52-59 Ford Group, we've got some Merc guys there that might be able to help you.
    Maybe a few pics too.
