Thumpr cams-any input on SBC use?
Discussion in 'The Hokey Ass Message Board' started by Groucho, Jan 21, 2014.
  1. I see where you are now.
    So while the cruising rpm is approached at 17-2200 Rpms, there's few few ears that can hear if a car has any type of performance cam in it. At the stop lights the owner can make rumpity rum pit ***ty rump noises and have a car that works and they can make the noise. The alternative it a car that makes noise at low rpms and the owner needs to compensate and deal with a car that doesn't do anything else very well.
  2. hoop98
    hoop98
    from Texas
    Or you can run the RV but use a manual choke and pull it out at the light :)
    240H
  3. hoop98
    hoop98
    from Texas
    Sum 1105 Vs Thumpr, now remember we are dependent on published specs. I used .050 because Summitt has really long advertised.
  4. sunbeam
    sunbeam
    The cam was made to give " the idle" but keep reasonable driveabilty. Like all cams that have low idle vacuum the idle circuit needs to be richer. Sense the Idle circuit stays in play until about 2000 rpm you can expect lower fuel mileage.
  5. jkeesey
    jkeesey
    A buddy of mine (a pro NHRA engine builder) has said he will not install a thumper cam in and engine. Claims its too hard on the bottom end. Personally I have never used one before, I have used the Summit brand cams with I would say good results. Never a breakage and good for basic cruises. I don't build all out race cars.
  6. beachbum jim
    beachbum jim
    from Loris, SC
  7. hoop98
    hoop98
    from Texas
  8. I'd love to hear more on why he believes that:confused:
  9. hoop98
    hoop98
    from Texas
    Quote:
    Originally Posted by jkeesey View Post
    A buddy of mine (a pro NHRA engine builder) has said he will not install a thumper cam in and engine. Claims its too hard on the bottom end. .
    Me too, here are the Gas Forces and BMEP for the Thumpr and XE274
    __________________
  10. jkeesey
    jkeesey
    He claims something about holding the charge puts un-needed stress on the bearings and leads to premature failure. I don't know, Im not a doctor. I just fix old cars.
  11. sunbeam
    sunbeam
    huh???
  12. Johnny Gee
    Johnny Gee
    from Downey, Ca
    I'd say it's the pedal pusher that's hard on the bottom end, not the cam ;).
  13. In "theory" something harder on the bottom end/bearings (outside of detonation of course) is just about anything that's got potential of making more power, no?;). So, if you want to protect the bottom end/bearings....no big compression/blowers/turbos/nitrous?
  14. jkeesey
    jkeesey
    If I remember right he claimed it was similar to running with your timing too far advanced. I haven't talked to him in a long time, its been a while since I did any SBC work.
  15. jdubbya
    jdubbya
    I have the Thumpr in my truck, like said before, the only thing I would have done different is go with a higher stall converter. I opted for a 2400 stall, and wish I would have gone with a 2800-3200.
    I am happy with my set up, it is a hydraulic roller in a 98 SBC. The motor is basically stock, except for a little port work on the heads, and of course better valve springs. Here is a video link.
    <iframe width="420" height="315" src="//www.youtube.com/embed/kpypBWBOCo8" frameborder="0" allowfullscreen></iframe>
  16. gasmanm01
    gasmanm01
    I have one in my f-1 ford with a 5-speed , small block, and the original dana rear. Pulls good in second- 4th gear, shift into 5th and around 1900- 2300 rpms, you can really feel it, and gas milageis unreal with thisset up. I thought everyone onthe hamb were 3 pedal guys.
  17. black 62
    black 62
    from arkansas
    Joe Sherman likes them...
  18. tjet
    tjet
    Great vid - sounds good.
    Are you running a vacuum advance?
    As to original question. Why not get one & try it? Get that 2 piece timing cover so it's easier to swap it out if you don't like it.
  19. hoop98
    hoop98
    from Texas
    If you wonder what you are giving up compared to a conventional grind here is a Comp 280H vs The Small Thumpr.
    The 280H is slightly better up to 5500 then the big exhaust pays off.
  20. 1971BB427
    1971BB427
    from Oregon
    Don, the Summit brand cams are built by Crane. Most of them are just Crane Cams in the same grinds Crane sells, but their are a few that are circle track cams that Crane grinds to Summit requirements.
    I've used numerous Summit/Crane cams, and never had any problems. Very nicely made, and durable. I had about 13 years of driving with one on my Camaro's 427 when I sold it last year. I wouldn't hesitate to use them; they're a real bargain!
  21. 1971BB427
    1971BB427
    from Oregon
    I chuckle when someone says a certain cam is harder on the engine because of it's specs. I'm also running the middle Thumpr in the BBC in my Falcon in my avatar. It's got gobs of low end torque, and makes power well beyond where I should be running the engine! Revs quicker than most the SBC engines I've owned, and I really have to watch the shift light to make sure I don't over rev it! I'm running a 4 speed, but an automatic with this particular cam would need a 2500 stall converter, as it's got a pretty short 108 LSA. Click on picture to play the video:
  22. Harrison
    Harrison
    I had a Thumpr in a .030 over 283 with a stock torque converter on a 700R4.
    It sounded like feeding time at the zoo but it had NO low end torque and burned more fuel that a four-motored air plane.
    I'm sure that, with the right combination of parts, they are fine cams but I wasn't happy with mine. The sound wasn't worth the absolutely ****ty performance my set-up was delivering.
    JH
  23. YIKES! All I hear's the gear drive. LOL
  24. Harrison you have hit on something that most will never get. Unless you go with the absolute smallest or closest to stock performance thunmper cam you can find you are going to have to build the engine to support the cam shaft if you expect it to perform.
    Now for those of you who have not written me off as a hater and are still reading, that goes for about any camshaft. Close to stock cam stockish engine fine, lots of cam stockish engine, dawg.
    I gotta laugh, I was in a gas station a year or so back and this guy pulls in in a first gen effie. I thought he was running a diesel and I remarked that it was a novel idea. he said not diesel SBF and a Thumper. To each his own I guess.
  25. fsae0607
    fsae0607
    ^^^ Yeah but Comp says they're supposed to sound "cool" :confused:;):D
    I was considering one for a 327 for my truck, but after researching the HAMB (of course) I'm choosing one of their Xtreme Energy grinds.
    Like someone else said here in another thread: "No one ever bought an L79 cam for the way it idled." :cool:
  26. Gman0046
    Gman0046
    I guess there are Thumper Cams just like there are Gear Drives. Whats the point? I'm just not impressed by a bad *** idle.
  27. Don's Hot Rods
    Don's Hot Rods
    from florida
    Thanks for that information. I may just have to try one on the 350 I am doing right now.
    Don
  28. norby48
    norby48
    from NW Indiana
    I used Blue Racer cams in all my small blocks. My '57 Ford with a 406 sbc, 10.2-1 comp, World Prod. 200cc heads, RPM intake, 750 HolleyDP, Had a stock car grind, (something like 236/4.80), 700R4, 3.90 gears. Ran 12.90 and got 20mpg @ 60mph all day long.
  29. 1971BB427
    1971BB427
    from Oregon
    The entry level Thumpr I stuck in my buddy's 350 in his '48 Austin A40 is getting 20 mpg on the freeway at 70 mph the last road trip we made. That's with a TH350, and 3.73 rear gears too. I'd call that acceptable mileage for a rod without OD.
