Projects 40-41 ford spare divit patch panel
Discussion in 'The Hokey Ass Message Board' started by SSKINNER, Jan 25, 2014.
  1. SSKINNER
    SSKINNER
    Hey,
    I've got a 41' ford truck. I'd like to keep it all steel. Does anyone know if anybody makes a patch panel to eliminate the spare tire divot in the right rear fender?
    Thanks,
    Steve
  2. john worden
    john worden
    from iowa
    I doubt that anyone makes it. Shape one yourself or use a piece from a junk fender.
  3. SSKINNER
    SSKINNER
    Maybe I worded it wrong. I have tendencies. What I meant to say was that I want to remove the divot completely and make it match the other side. The way the gl*** fenders are made.:confused:
  4. greener200
    greener200
    believe it or not I,ve seen them just pounded out ,no adding or subtracting just a skim coat of plastic . so you must have a 38-9 fender . I thought 40 41 fspare-tires were mounted on the drivers side .good luck mp
  5. Jim636
    Jim636
    from Wyandotte
    Just cut it out and make a patch,that's what I did on mine after someone beat the **** out of it. The spare tire divet was on the p***anger side of my truck.
