Technical 18" wire wheels and tires, 700-18 tires, too big???
Discussion in 'Traditional Hot Rods' started by Chris Casny, Jan 13, 2008.
  1. A BONED
    A BONED
    Thanks boys for your advice
    I don't really mind the newer tread pattern 700-18 Firestone
    Just kinda love the old pie-crust versions more
    I can see in my minds eye everybody silently nodding with me...
  2. A BONED
    A BONED
    Those dirt trackers look the ****
    Great choice...!
  3. CTaulbert
    CTaulbert
    from Detroit
    I'm bringing this thread back up, as it pertains a lot to the 7.00-18 Firestone that is no longer made.....
    Well if you haven't seen my thread, Coker Tire is doing a limited run in the "old" tread pattern. Check out the link to my thread, and get a hold of me through PM or email if you're interested in joining the pre-order. We only have about 24 tires left......
    http://www.jalopyjournal.com/forum/showthread.php?t=832691
    AV8R likes this.
  4. dsiddons
    dsiddons
    from Indiana
    Them 18"s look awesome with Lester tires do it!
  5. DirtyJoe
    DirtyJoe
    These are 7.50 18 on the back. I will be getting a taller 16 for the front.
    The 18's fit just fine on the wheel.
  6. Christom
    Christom
    Dude - that is a serious "big 'n little" combo you have there! Cool!
    Here I was concerned with running 7:00-16 tires on 4" wide '40 steelies...
    I did find they only ran on 3/4 of the tread width though.
  7. Anyone have pics of a 28/29 Tudor with 18's on the rear, stock springs WITH fenders. I'm thinking of 16's in front and 17 or 18 in the rear as I want to take up some wheel well, but still retain some suspension with rear p***engers. I might reverse the spring eye only or pull some leaves with the stock eye.
  8. Hitchhiker
    Hitchhiker
    Not a tudor, or a 28/29. but if you go look at my thread, my 31 pickup is fullfendered with a 7.50x17 with a reverse eye spring in the rear with 6 leaves and the front is a dropped 36 axle with a reverse eye. and 5.50x16's
  9. 4 banger 4 life
    4 banger 4 life
    from ohio
    Hell ya 7.00 18,s on the rear are the ****.... too bad coker dont make a ***y 4.75 5.00 0r 5.25 5.50 18, in a gum dipped to match the rears....
  10. Gearhead-DK
    Gearhead-DK
    Hey Youngrodder… where'd you find that picture?? I have been searching for a pic of that garage for a long time! :)
    I seem to remember seeing one where a green(ish) tudor is sitting in front
    Can you help?
    Sorry for this being off the thread topic
  11. youngrodder1929
    youngrodder1929
    That pic is off the hamb some where its been some time now I believe the Tudor was from the same family the Kennedy's I believe
  12. hotrod-40
    hotrod-40
    run the 18's. I had 700 18's on the back of my old coupe
    project starter likes this.
