White engine compartment
Discussion in 'The Hokey Ass Message Board' started by lukey, Jun 6, 2012.
  1. lukey
    lukey
    Who here has a white engine compartment and how hard is it to keep clean? Im giving some thought to spraying my firewall and inner wheelwells gloss white on my 58 ford. The engine will be body color (most likely a medium blue metallic, or black) with very little chrome or polished aluminum. Going for simple but clean. Post up any pics u have, i need ideas. Thanks!
  2. cederholm
    cederholm
    I don't know from experience with white, but if you keep in gloss and aren't leaking oil everywhere I bet you would be okay. ...of course it would require more attention to keep it nice, but from what you described it would be worth it. I love the blue car, white bay, blue motor with some polished aluminum idea. That would look amazing!
  3. 1951Streamliner
    1951Streamliner
    from Reno, NV
    As long as its gloss it will be fine. I had a satin white on my inner fenders and it was a pain and a half to keep clean, so over time they just turned to a solid grey color :eek:
    Now they're shiny black and maintainence free, but I definately think you should go with the gloss white, white engine compartments just look so good
  4. ModelAPunk
    ModelAPunk
    from Buffalo NY
    I'm actually wondering the same thing! Was going to paint my engine compartment and inner fenders gloss white on my 53 Chevy. Please post some pics of white engine compartments!
  5. cooljunk
    cooljunk
  6. tedley
    tedley
    from canada
    I'm a ****** for not spending enough time under the hood. I got a feeling i am going to now thou.
  7. lukey
    lukey
    Ok, gotta hyjack my own thread a bit...Tedley, how did you mount the FE Style valve covers on a smallblock? Ive seen it done, but havent figured out how!
    -LUKEY-
  8. tedley
    tedley
    from canada
    I took the easy way out, i bought the adaptors
    here's info
    http://home.comcast.net/~superhart/vcadapter.htm
  9. DERPR30
    DERPR30
    from HARVEY LA
    Here is a pic
  10. cederholm
    cederholm
    ..and what a nice pic it is! Beautiful car/motor/firewall etc...
  11. Regular wash and wax under the hood.
    Keep it clean and it shouldn't get too overwhelming.
    Build it so its easy and not problematic to regularly hose it down.
    Road dust is going to be your biggest enemy here. The fan will blow all of the dirt it sees on everything behind it.
    I knew a guy who painted his whole underside white, it was beautiful.
    Great wax and some extra creeper time kept it nice.
  12. Canuck
    Canuck
    Must be a Winnipeg thing to do ---
    47 Chev with 454. Just took regular cleaning. Wouln't want to go that way if your engine leaked a bit. :eek:
    Canuck
  13. Von Rigg Fink
    Von Rigg Fink
    from Garage
    nice contrast yes, PITA!..definetly..
    but its all in what its worth to ya
  14. glendale
    glendale
    here is mine not done yet **** i am liking it so far.
  15. notrod13
    notrod13
    from long beach
    i always use antique white on the firewalls of my cars ... keeps it clean and is easy to tale oil off of and touchups are a breeze
  16. uncledon529@bellsouth.net
    from florida
    White is better then the black I had, brightened up the engine compartment a lot.
  17. What I have noticed is that most white turns brown where it gets near the exhaust. But keeping it gloss does help with normal cleanup. You cannot touch it up as a rule because it does discolor.
    I think it is an exceptional color for a custom as long as there is something with the car to match it. It wants to be a reflexion if something else on the car like for instance the interior or the dash. Also I think that you would want to mimic the car with the engine color. It keeps things from getting out of hand or busy. Just my thoughts on the subject.
  18. cruzr
    cruzr
    white firewall for a long time
    Tim likes this.
  19. Jcurtisward
    Jcurtisward
    from Tucson, AZ
    I haven't had too much trouble keeping mine clean yet.
  20. Canuck
    Canuck
    Had the problem of the engine turning brown around the exhaust ports on my 47, of course after everything was together and on the road. In frustration touched it up with Krylon lac and it stayed good for years.
    Canuck
  21. lukey
    lukey
    Anymore?
  22. lukey
    lukey
    Bump for some inspiration
    -LUKEY-
  23. 4 banger 4 life
    4 banger 4 life
    from ohio
    x 2 for the white gloss and keep her clean....
  24. sidevalve8ba
    sidevalve8ba
    Here's mine. I agree with the gloss paint thought also. It works for me. Keeping oil leaks to a minimum is a big plus too.
  25. SmokinBill
    SmokinBill
    Stock white color with clear coat, I've got about 9k miles on it so far. Makes the motor look better.
  26. mad mikey
    mad mikey
    My engine block is snow white, you cant really tell from pic in my avatar, but it still looks awesome after 6 years. Just use high quality Paint. and clean up every now and then!
  27. metalman
    metalman
    I use white a lot in engine compartments, it seems to highlight the engine instead of swallowing it up like black does.
    On this 39 I'm building I even painted the floor white, I have spent a little more time in the detail on this build and want to show it off more when someone does get down and look under. FWIW the interior is going to be white so it kinda all goes together.
    Like other say the key to keeping it look good is good quality gloss paint and keep up with the cleaning, a quick spritz with windex and wipe with a rag usally does it.
  28. jerry sezar
    jerry sezar
    We built up a '39 ford hardtop for racing three years ago and due to rising paint cost and prep time I elected to send it out to Maas Powdercoating in Livermore. I had Kraig blast the entire car as the frame, cage, and body are one piece. Then primer, then epoxy white 100% gloss. We have raced the car for two years at all the local tracks and the best part is we just use the presure washer to remove clay and grease and it looks like brand new again. White sure makes it easier to spot problems when we have mishaps like hitting walls and other cars. PS....were running a flatty.
  29. Orn
    Orn
    I haven’t been able to drive so much yet since painting the white but time will tell….
