Falcon V8 Project
Discussion in 'The Hokey Ass Message Board' started by Thefult, Jan 26, 2014.
  1. Thefult
    Thefult
    from Fairbanks
    Alright, after a bit of thought and lack of knowledge, I would love to replace my '61 Falcon's 144 I6 with a 302 V8, but I know mounts will differ, and oil pan depth will make things tricky.
    Twist is, I would like to try to keep it all original enough that I can simply drop the 144 back in when ever I feel like selling the old bird.
    So how hard would it be to swap a V8 in to a Cl***ic Falcon and what steps should I take to begin.
    Thanks! =D
  2. rustang
    rustang
    You will want to upgrade the rear diff and the front end components.
  3. gimpyshotrods
    gimpyshotrods
    Yup. I broke the 6-3/4" rear in my '60, after I hopped-up the 144 a little. Wiped out the output shaft bushing, and shattered the front u-joint.
    Now it has an 8.8 from a 1991 Ranger.
    Also, the tunnel is a tight fit for about any V8 transmission. I have a T5 in mine, and had to tip the engine down to 5º to get it in there, without butchering it. I wanted to run a stock carpet.
    If you can find one, you can get a later tunnel, and weld that in.
  4. Judd
    Judd
    I put a 289 with t10 4 speed in my 60 Falcon I used 64 comet v8 mounts fit like stock. The only mod to floor was hole for shifter. I used a 57 Ford 9" rear axle fit right in . I did zero front end mods even had 4 lug 13" wheels and dog dish caps
  5. sunbeam
    sunbeam
    There's a set of 63 v8 mounts on ebay you will have to notch the pipe cross member to use them. Do not delete the cross member on these early cars.
  6. ttpete
    ttpete
    from SE MI
    The first V8 Falcon I ever saw was in the fall of 1959. It showed up at Detroit Dragway on grudge night and ran in the 14s on its first p***. Turned out it was from Dearborn Steel Tube and was powered with a 312 Y-block.
  7. hoop98
    hoop98
    from Texas
    Falconparts dot com is a good start.
    119.95 Engine Frame adapters
    Here is a snapshot of their V8 Mounts
    safetythird and falcongeorge like this.
  8. 1971BB427
    1971BB427
    from Oregon
    What cross member are you referring to? I didn't have any engine cross member on my '63, and trans cross member was not "tube".
  9. If I remember correctly on the early Mustangs ('64-'66 at least) Ford used the Fairlane suspension when they used the V8 and the Falcon suspension for the six. I ***ume the Falcon with a V8 came with the Fairlane suspension. I would sell the car and buy one that came with a V8. As far as the resale value goes I would never buy an eight cylinder car that started life with a six.
    Charlie Stephens
  10. hoop98
    hoop98
    from Texas
    This one:
    May want to look here
  11. gimpyshotrods
    gimpyshotrods
  12. customrod48
    customrod48
    Just finished doing this on a Ranchero-pm me for a ton of info and resources, I referred to the Ford Falcon Forum, "TFFN" they will walk you thru everything.
    V-8 Mustang front end parts except drag link must be from a V-8 Falcon....
    Transmission must be from a Comet or Falcon if using a T-10 or toploader as the shifter is located way forward on a Falcon/Comet.....the tube looking gizmo in one of the above replies is actually a frame stiffener used on conversions and is bolted to the motor mounts to stiffen the frame on V-8 conversions. Flat style after market will not clear the drag link on these conversions..just a few nuances to look out for.
    If interested, send me a pm for more resources and tips
    ecwool likes this.
  13. Thefult
    Thefult
    from Fairbanks
    Wow, A lot of answers thanks :D
    Now I got a 3 speed automatic in it right now, the FordoMatic, are there any V8 swaps with those being used?
    The rear end I can do with swapping, and the little swaps in the front, but the ****** would be nice to keep as it doesn't make me do any thing under there.
  14. hoop98
    hoop98
    from Texas
    That Fordomatic is a 2speed. Get you a donor with trans.
  15. One thing I never see come up (and it should) is the fact that the six cylinder Falcons/Comets/Mustangs had a much weaker body shell. When Ford added the V-8 to these cars, they not only added torque boxes between the frame rails and the rockers, but they also sharply increased the metal thickness of the framerails, inner rockers, and most of the suspension mounting points. If you stick with a mild motor and an auto trans and don't beat the car, you will usually be ok. But I have seen a couple of catastrophic failures in higher-HP/stick swaps, and cracking appearing in various places on daily-drivers.
    Ford did use the heavier bits in some six cylinder cars; Rancheros and wagons got the heavy-duty rails at the rear, and all convertibles got the V-8 shell. Mercury used the heavier V-8 shell in all the 64-65 Comets, regardless of body style or motor.
  16. falconeer
    falconeer
    You can use a 70-71 Maverick-Comet 8" rear end(5-lug) or if you want to keep every thing 4 lug use a 70-to early 71 Mav-comet rear,its still an 8" Better if you can find a 63 V8 Rear end. With the Mav-Comet you can use 67-70 mustang spring plates and u- bolts 260-289-302 you can use your z bar may have to modify a little. you can also do clutch cable or a hydraulic clutch. 3-4 or 5 speed.
    Butch Evans(Faconeer)
    Thomasville NC
  17. Kinky6
    Kinky6
    He would have to buy a '63 or newer to get a stock V8, that's when the Sprint came with a 260".
    Up until then, a 144 or the later 170 were the only choices. The O.P. would do well to go ahead and swap out the front suspension and rear end for V8 spec parts and an 8" or 9". There was a reason the Ford engineers did this; no point in second guessing them on this.
    Later, *****6 :cool:
  18. Johnboy34
    Johnboy34
    from Seattle,Wa
    Wow, I guess my 63 Sprint rear end and motor mounts are worth something?
  19. You should also add a cross brace, tower to tower.
  20. falconeer
    falconeer
    Johnboy, I have the same thing,63 v-8 rear end, 325 gear, complete set of motor mts. 74 Comet 5 lug rear with a 325 gear, T-5 5 speed, On and on. Going in a 62-63 Ranchero.
    Butch Evans(Falc0neer)
    Thomasville NC
  21. Mike51Merc
    Mike51Merc
    I've read (but never measured myself) that the space between pre-63 Falcon suspension towers is narrower so you need to be careful if you plan on installing headers. I think the tri-Y headers avoid the narrowest part of the towers.
    If I was doing this job I'd install an export brace, a Monte Carlo bar, and cross member under the engine. Swap out the front control arms and spindles for 5 lugs, and swap the rear for an 8".
    By the way, the Falcon 8" rear was the narrowest rear ever produced by Ford. Any other rear will either have to be narrowed, or you may have tire clearance problems.
  22. raven
    raven
    Many use the Granada spindles to get discs up front.
    r
  23. 1971BB427
    1971BB427
    from Oregon
    Thanks! I'm guessing those were only on the earlier Falcons since my '63 didn't have one?
  24. hoop98
    hoop98
    from Texas
    I am not sure which ones had it but a lot of them got left off after a main seal job. My 64 Sprint 260 convertible had one.
  25. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    The only 63's I've seen with a factory under engine brace were I6's...but I could be wrong.
    I often am, just ask the Missus.
    Here's an aftermarket "under engine brace" for V8's:
    Came from Melvin's, I think: http://www.melvinscl***icfordparts.com/
    And my home-made removable Monte Carlo bar:
    I hear Sanderson is now making "tight fit" headers for Falcon V8's w/ AOD transmissions:
    http://www.sandersonheaders.com/Sanderson-FF6-Small-Block-Ford-Blockhugger-Header-Set.html
    I can't afford 'em at the moment...
  26. 1971BB427
    1971BB427
    from Oregon
    Maybe it was just left off mine when they swapped the larger I6 into it. I know mine was a factory I6, but no telling what might have happened over the years. Since I did all the frame mods to add the heavy box tubing to the lower frame rails for the BBC, there's no way to go back and look now to see if the holes were there. I don't remember them from when I was cleaning and grinding, but that's no surprise. ;)
  27. Mike51Merc
    Mike51Merc
    There are no holes for the cross member mounts. It uses the same three (on each side) mounting bolts as the motor mounts.
  28. gimpyshotrods
    gimpyshotrods
    The Ranger pickup 7.5 and 8.8, circa '90-'92 is 1/2" wider, but has an offset pinion. It can work, with some floor tweaking.
  29. Ben Blackwell
    Ben Blackwell
    I used a rear end from a 59 ford fair lane under my 61 it worked perfect and a c4 or c5 automatic will work with no problem I used one from a 76 mustang because it has the small bell housing and torque converter and I used the oil pan from the same car because the are rounded on the small part of the pan gives you plenty of clearance. I also used the manifolds that go straight back that way they cleared everthing. My 63 I used everthing from a 74 mercury comet motor trans rear end front end master cylinder break boater the whole nine yards.
  30. sunbeam
    sunbeam
    I put a 221 in my 60 in the early 60s used a 59 wagon 9 inch it was 3/8 inch wider than the falcon unit and the spring pads were in the same place a bolt in.
