Projects 26 roadster build; Bang Bang
Discussion in 'Traditional Hot Rods' started by h.i., Nov 4, 2012.
  1. h.i.
    h.i.
    from denver
    One more for tonight
    OFT, Shadow Creek, brEad and 3 others like this.
  2. Squablow
    Squablow
    Looks good! Sits really nice, top of rear tire right where it should be, grille lined up with the front axle. Very nicely proportioned.
    brEad likes this.
  3. 26 T Ford RPU
    26 T Ford RPU
    Happy New Year guys, like the progress and the stance on that profile shot is oh so perfect. JW :)
  4. LSR 2909
    LSR 2909
    from Colorado
    Your metal working skills are way better than mine!
    Looks good.
  5. Equipped28
    Equipped28
    liking this, giving me the kick up the **** to get on with mine
  6. gonzo
    gonzo
    Love that spreader bar!
  7. Such a sweet build!
  8. h.i.
    h.i.
    from denver
    Wow, thanks guys. Good motivation to hear positive feedback. Miss you at club LSR, we need a band saw guy haha. Hope to get some good stuff done tonight. Ill try to post some progress tomorrow.
  9. h.i.
    h.i.
    from denver
    Great progress last night. Pineapple was working on the drag link while I got the revised dash in and bolted up the column drop. We also had to work out a plan for a shim for the steering box to the frame. Not much to see here yet.
    Finally, we cut and fabbed the new mast jacket, shortened the column and fit the steering wheel. Still have some machine work and finish welding, but it's close to steering on it's own.
    OFT, brEad and kidcampbell71 like this.
  10. ml_engr
    ml_engr
    Really liking the look of your build. Keep up the good work
  11. Cowtown Speed Shop
    Cowtown Speed Shop
    from KC
    Good job on this roadster, You nailed the proportions.
  12. qzjrd5
    qzjrd5
    from Troy, MI
    Love this build, and your sense of humor!! You are doing a great job!
  13. Mindover
    Mindover
    from England
    Looking superb.
    Rabid
  14. Coming out beautifully!
  15. [​IMG]
    just going back through the thread. noticed what month it was oooh la la!
  16. Mr48chev
    I have no idea how I missed this one but I just read all 16 pages and what a great build and what a great looking profile on that car.
  17. lorodz
    lorodz
    awsome build....
  18. PINEAPPLE
    PINEAPPLE
    ImageUploadedByH.A.M.B.1390111160.769220.jpg ImageUploadedByH.A.M.B.1390111179.744415.jpg
    Thanks fellas, I had some insomnia last nite, and had HI's steering bits around, so I winged out this 4 degree shim to put the column right where it should be once bolted to the frame. No excessive binding needed.
    Matt.
  19. LSR 2909
    LSR 2909
    from Colorado
    Beautiful job PINEAPPLE!
  20. Shaun1162
    Shaun1162
    Awsome progress! Can't wait to see this one done....
    You've probably figured out your exhaust already, but I see that the F-1 box is pretty close to the block... I'm sure you're going custom headers or something, but if you're "boring" like me, I found these stock Ford manifolds that exit out the front. Got my out of jam when I had a flathead in my stock car (I ended up relocating the dip stick on mine):
    brEad likes this.
  21. PINEAPPLE
    PINEAPPLE
    Shaun, yeah, we will make custom headers, which should prove to be quite entertaining for anyone following this thread:D:D probably have to fill the f1 box with grease to keep it from boiling out:p
    brEad likes this.
  22. h.i.
    h.i.
    from denver
    Thanks a lot guys, appreciate all the great comments! Nice work on the shim Pine, love it when you can't sleep, haha.
    Pineapple didn't post the single point threading on the shortened drag link, cool as hell. Have to put the steering box back in and index the wheel to finish up the column.
    Have not decided on exhaust yet, but one of the many benefits of moving the F1 box back towards the cowl was a hell of a lot more room for either lake pipes or running inside the frame...
  23. PINEAPPLE
    PINEAPPLE
    Oh yeah, forgot.. Here some drag link shenanigans that keeps welding out of the equation for the drag link. Former model a tie rod, kept the left hand thread end, cut and thread a new right hand thread. No die for this one that I'm aware of.. ImageUploadedByH.A.M.B.1390147562.736782.jpg ImageUploadedByH.A.M.B.1390147588.921799.jpg
  24. PINEAPPLE
    PINEAPPLE
    Why does it post pics twice? Cause I'm a dummy? O.K. then, got that out of the way. I dont wanna hog the internet..
    brEad likes this.
  25. Six Ball
    Six Ball
    from Nevada
    Hog it all you want. If you're building stuff like this we need to see it. This car has come a long way since page 1. Nice job!
  26. greaser
    greaser
    Great job!
    Just a suggestion.....You could fly cut or grind the back side of the steering box flange slightly at the hole locations at 4* also. (To keep bolt head and nut surfaces parallel). This eliminates the need for tapered washers when you bolt the steering box to the frame using that wedge.
    brEad likes this.
  27. PINEAPPLE
    PINEAPPLE
    Thanks greaser!
    I thought of doing that, but the amount to be removed would have gotten into the sector shaft seal counterbore more than I was comfortable with. I drilled the holes in the flat position before milling the angle, this way the holes are still perpendicular to the box flange, any diving off of the bolts through the frame should be sorted with lock washer crushing, if not, we will make an outside frame rail plate, to match…hmm, that could be a fun too.
  28. GARY?
    GARY?
    An outside plate might be a nice touch. Lookin' good.
    kidcampbell71 likes this.
  29. PINEAPPLE
    PINEAPPLE
    I agree, Gary. Thanks, nice to hear from you. Hope all is good for you.
    Matt
  30. Cali4niaCruiser
    Cali4niaCruiser
    I agree, outside plate would be trick. H.I. and Pineapple, you guys are doing great work. I see an awesome car in your future.
