Features Doing Falcons Right
Discussion in 'The Hokey Ass Message Board' started by falconizer_62, Jul 23, 2008.
  1. gimpyshotrods
    gimpyshotrods
    The stock fill disallows the full-flow use of a, current-generation short snout California vapor recovery fuel filler nozzle.
    Even with a clean, oversized vent hose, I can't fill past half-flow, without creating a large puddle, or taking a gas bath.
    I will be relocating mine, with any luck, before I get shived for taking 15-minutes to fill up.
  2. BurntOutOldMechanic
    BurntOutOldMechanic
    from NOVA 22153
    Screw 'em, Gimpy. At $3.929/gal for 93 octane here in the east, I take as long as I need to.
  3. 1971BB427
    1971BB427
    from Oregon
    Sort of, but not. I got some black teflon from the local TAP Plastics store and made a base that straddles the trim and contoured it to the shape of the tail panel. That way it fits the panel, and gave me a flat base to bolt the filler door to without smashing the trim. It also set it off enough to sit flat and make room for a gas cap under the door. The top and bottom of the door is almost flush, with the area between built up to clear the trim.
  4. redzula
    redzula
    The tank looks about the same as a 64-66 mustang tank. Anybody tried to swap one of those in and use their straight shot fill tube? Probably going to try this when I get ready to swap out my leaker.
  5. Locoxp
    Locoxp
    Yep they are the same, I put a 65 mustang tank in my wagon.. Only difference I can see is the wagon fill point is in the side of the rear quarter and to the side of the top of the tank.
    I've seen it done before and quite a nice trick if you like a clean look is to hinge the rear tail light and locate your filler cap behind it. Then delete the original fill point
  6. 2dr_sedan
    2dr_sedan
    One of my favorite threads
  7. redzula
    redzula
    That's a slick idea I've never been a fan of the stock fill cap it's just stuck right in the middle of the falcon letters and looks out of place. Need to get a few projects done though before I turn this car into a project car haha.
  8. gimpyshotrods
    gimpyshotrods
    I scored a Jag XJ cap to go up on top of the fender, by the back window. I will get a fresh '70 Mustang tank to replace the stock on in my '60. That will put my capacity at 22-gallons, up from 14, and will save me from welding on a used tank.
    Just need to build a little recess for it in the fender, so it looks like is was always there.
  9. bengeltiger
    bengeltiger
    Sounds slick. Be sure to post pics, please!
  10. Leon Sandcastle
    Leon Sandcastle
    1391829625541.jpg Even though I think g***ers are being over done, this Falcon has some nice touches.
  11. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    Nice and smooth
  12. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    So..when does it ever stop. :rolleyes:. So she says HA!
    Trans arrived from AstroPerformance. T-5 A5 built for 500hp and 480TQ. Nice piece. Stepped up to the 26 spline input. Upgraded the clutch to a 26 spline hub, ceramic faced. Corrected throwout bearing issue and length.. Corrected belljousing clearence issues. Stabbed the trans first shot.
    Currrently installing the CPP mini front sub frame. These cars and the novas have a very similar front end. The front mini sub is a no brainer.
    The strut rods get cut out and the suspension is now fully adjustable.
    So far I like everything about it. I cannot wait to drive this car without any bumpsteer. pics soon
  13. SOCAL PETE
    SOCAL PETE
    from Ramona CA
    Seroiusly thinking about another fill point. I just piscked up a new 16 gallon tank/drainplug and sending unit
    (rockauto) $152 delivered.
    Either a Jag or Cobra Cap.
  14. hotroddon
    hotroddon
    I don't see anything in the kit that will change the bump steer in these cars. They don't move the LCA pivot point or the steering arm location, so it won't change Bump Steer. In fact I can't see any advantage to this kit at all to be honest. All it does is replace the strut rod with a lower control arm with two pivot points which does nothing as far as bump steer goes. I'm not sure what you mean by "Fully Adjustable" as you have no more adjustment than stock, it just moves the camber adjustment from the upper control arm to the lower pivot and the way it adjusts only on the rear bushing of their arm will induce bind on the other bushing, although probably not enough to cause any issues. There is nothing wrong with the strut rod as long as the bushing are in good shape and if you want to upgrade that the kits from Global West or TCP that use a heim joint are much better and they make the caster adjustable though the strut rod. Unless I'm missing something here, and I have looked at this kit a bunch, I think all it does is add weight without being as good as the stuff from Global West or TCP.
  15. gimpyshotrods
    gimpyshotrods
    Without altering the length of the tie rod, in relation to the lengths of the control arms (I.e. movng the inner ends inboard), this will do nothing for bump steer.
    The bump steer solution on an early Falcon is to use the later model center link, and tie rods.
    That kit is a useless wallet lightener.
  16. gimpyshotrods
    gimpyshotrods
    Got the Jag cap, for $30, delivered. Just need to fab up a little recess, and drop it in to the quarter panel.
    Even though it is a later model part, it still, to me, has a 60's vibe to it.
  17. stickerdick
    stickerdick
    OK, I might be posting in the wrong spot, if I am, I am sorry. I just picked up a 1964 Wagon, I am planning on doing a low budget "SURF WaGON" theme and I don't know much about Falcons.
    I want to run 60's style rims and white wall tires, but I don't want to use 14" or 13" rims. I like the Salt flats rims and I'm trying to figure out how to go 5 lug first, how to drop the front end w/o cutting coils, I'm not a fan of that, I plan on using a 2" block on the rear.
    I will stick with the 6 cyl and auto that is in it now, it has A/C, but I want to get the stance right first. Then I 'll consider a V8 swap
    Any suggestions or advice on how to achieve the look I want and what size tires/wheels I can go with would greatly be appreciated.
  18. cage66
    cage66
    from reno
    So I am going to be buying some Trus from Chip (louvers) and I will not need the ones I picked up. 3 are the same and 1 is different Let me know if anyone is interested. I need $150
  19. cage66
    cage66
    from reno
  20. gimpyshotrods
    gimpyshotrods
    The last Falcon wagon I did ran 195-60-15's, on 15" x 6".
    You don't want to over-do it on tire height. The taller the tire, the bigger the cir***ference. The bigger cir***ference will make it seem like it has taller gears. This is not good for the six.
    There is no way to lower the front end without installing shorter coils, or cutting coils, or both.
    Might I ask why you don't want to cut the coils? I have been doing it for about 30-years, and getting paid to do it for about 25. Done properly, it works just fine, and is a time-honored, traditional practice.
    My daily-driver '60 Falcon runs 560in.-lb. springs, intended for a 65-66 Mustang, with one coil cut off, and custom 6-leaf rear springs from ESPO, which have 2" less arch when loaded. Your car can use everything from the Mustang parts bins for suspension.
    When you do have the front end apart, it is the perfect time to relocate the upper control arms. This is called the "Shelby Drop". While it does not really "drop" the car, it does "drop" the control arm. In the process, it radically alters the camber curve on suspension cycling, and during body roll.
    It is all of measuring and drilling 4 holes. The transformation is from grandma's grocery getter, to canyon carver. The cost is one drill bit. This is the single biggest, most cost effective modification you can make to a Falcon, or any other car that shares it's ch***is parts.
  21. Bull
    Bull
    Anyone making new rear lower quarter panels for the 60-61 Rancheros?
  22. cage66
    cage66
    from reno
    No, you either need to cut them out of a ranchero/wagon or modify the coupe ones.
  23. Bull
    Bull
    I'd ***ume modifying coupe pieces would be the way to go as most of the Rancheros and Wagons I see here are swiss cheesed from years in the rust belt.
  24. stickerdick
    stickerdick
    Cool idea on the "Shelby" drop. I have seen it mentioned on other blogs, had no idea what it did. On the cutting of coild, I just have had bad experiance on a 61 invicta I did and have always tried to use lowered coils since. I ***umed I could by a "lowered" coil from some dealer and just swap it out when I do the brakes and any linkage changes I might need to do once I inspect the front end. I have not really been under the car yet, just brough*** home on monday. Thanks for the info on the tires too.
  25. cage66
    cage66
    from reno
    They are still out there I bought a quarter recently
    I am thinking I will also shave the gas filler and try to hide it behind the tail light.
  26. cage66
    cage66
    from reno
    Whos on Istagram?
    I post most of the stuff I do on it, fabrication (work and home) sheetmetal fab, repair and other stuff mostly VW related but some falcon too. I have a 61 falcon wagon, 62 VW standard bus (slammed) and do work with friends too.
    Give me a fallow cage66_
    I also like to fallow others who build stuff.
  27. Leon Sandcastle
    Leon Sandcastle
    Check Desert Valley Auto Parts and a couple HAMB friendly salvage places for good rear quarters.
  28. need louvers ?
    need louvers ?
    I'd have to get the time to get up there, but I know a semi secret wrecking yard about 50 miles from my front door that had a clean pair of wagon quarters last fall. I'd be happy to check for you if you would like, and I bet they would be a damn sight cheaper than DVAP...
  29. fleet-master
    fleet-master
    I posted these on the metal shaping thread and thought you Falcon guys might be interested too :) This particular Falcon had been in the wars and had had a few different sections welded in here there and everywhere. first the old...
    and the new ...was best to cut it off and start fresh
    was a bit of a trick getting the gentle curve into the upper bodyline ,but it worked out pretty good and needed only a minimal ammount of filler to finish ,mainly on the joints.
  30. Nice Work ! and a great save on an early Kiwi Coupe .
