Flathead ford from a welder?
Discussion in 'The Hokey Ass Message Board' started by straight-shot, Mar 1, 2013.
  1. cmyhtrod
    cmyhtrod
    from ct
    Hope water didn't get in through the broken exhaust
  2. straight-shot
    straight-shot
    from Custer, SD
    I am going to do a little more exploring and see what else I can find out about it. All I know as of now is that it turns.
  3. MeanGene427
    MeanGene427
    from Napa
    One of my 8BA's was a power unit of some sort, no fuel pump so gravity-feed. They used to use them in wind machines, probably where it came from considering the location
  4. woodbutcher
    woodbutcher
    :D As of 1985,a friend in Florida with a citrus operation had 4 flatty powered welders that were in use almost daily.He had "0" complaints about them.As far as I know,he is still using them.
    Good luck.Have fun.Be safe.
    Leo
  5. Mr48chev
    Cool, I saw this unit today, Only a four cylinder flathead but pretty cool.
  6. MeanGene427
    MeanGene427
    from Napa
    A buddy's dad had a cool air compressor that was a flathead Ford with 4 cylinders running, and the other 4 pumping air- wild sounding ****er, and a pretty strong compressor
    dcool likes this.
  7. BobMcD
    BobMcD
    Do a cosmetic restoration and keep it intact. Tow it behind your rod. That thing is cool!
  8. dtracy
    dtracy
    Who was using the pipe wrench on the fan extention trying to get the engine to turn? Did it turn?
    Dave.
  9. sunbeam
    sunbeam
    How are the controling the rpm I don't see a governor
  10. flathead okie
    flathead okie
    I got one out of the s****yard a few months ago that ran a generator. A couple of weeks later I found a edmunds dual intake with carbs
  11. Raven53
    Raven53
    from Irwin Pa
    Nice score, I nabbed one a few summers ago out of an old road grader when we tore it down we found a 4" stroke crank in it I hope your find is as rewarding
  12. straight-shot
    straight-shot
    from Custer, SD
    The the guy I got it from used a pipe wrench on it to test it after I asked him if it was locked up. :confused:
  13. straight-shot
    straight-shot
    from Custer, SD
    I'm going to try to work on it this weekend.
    I haven't been around flatheads before. Where do you guys suggest I start? I don't want to screw anything up. I'm anxious to try to get this thing going!!
  14. Skavangs49_Merc
    Skavangs49_Merc
    from Sturgis,SD
    Maybe check the oil in it and ask around first before you test it with a pipe wrench but if it turns over then im guessing it is fine. I am no expert either but I would check the simple things. Check if it has spark. I wouldn't think you would ruin anything if you checked those things first.
  15. Skavangs49_Merc
    Skavangs49_Merc
    from Sturgis,SD
    Engines aren't my expertise but I sure like the look of those flathead engines they are cool.
  16. straight-shot
    straight-shot
    from Custer, SD
    Anybody interested in buying this flathead welder? I wanted to use it badly but don't have the time to dig into it and thought maybe somebody would like to buy it and be able to use it.
    If interested let me know here or pm me.
    Thanks!
  17. Larry Staub
    Larry Staub
    i just bought a flathead powered welder at auction. Looks home made? The front and rear axle are ford, wheels are from a ‘37-‘39 ford so I’m guessing the rest is too. I bought it for the motor but is there any value in keeping it whole? What did you end up doing with yours?
  18. hemihotrod66
    hemihotrod66
    I am no a fan of flatmotors so the Cleveland would be my choice....
    Brian Penrod likes this.
  19. Koz
    Koz
    I learned to weld on a homemade flathead welder. 21 stud on an angle iron skid out back of the shop hooked to a war surplus aircraft generator. Straight DC. There was a rod through the wall at the back of the shop that controlled the throttle. If you needed more heat you kicked the flattys speed up a bit. Worked great! A lot of water pipe roll cages for roundy cars built with it and I never remember a failed weld, (just everything else failed).
    Shame to cut this up to source a relatively easy to acquire motor.
    I understand this works. Just noticed it last week. A Lincoln 4 banger!
    Koz and Boneyard51 like this.
  21. Boneyard51
    Boneyard51
    WalkerMD, Jet96 and Koz like this.
  22. 1952henry
    1952henry
    There's a welder in local junkyard with a Jeep L-head 4 cylinder
    Boneyard51 and rusty valley like this.
  23. rusty valley
    rusty valley
    If its a WWII jeep motor its worth some dollars. Especially if it has a ford script carb.
    Boneyard51 likes this.
  24. You are asking/replying to a thread from 2014. You may know that.
  25. MAD MIKE
    MAD MIKE
    from 94577
    Someone needs to find a v12 Lincoln to power the Lincoln, and tow it with a Lincoln, so you can have a Lincoln in your Lincoln, while Lincoln'.
    WalkerMD, CSPIDY and Boneyard51 like this.
  26. Boneyard51
    Boneyard51
    And lock up the rear end with a Lincoln Locker! :p
    Bones
  27. Boneyard51
    Boneyard51
    You do know we deal in old stuff…..right? :rolleyes:
    Bones
  28. 1952henry
    1952henry
    It had jeep on the head, no GPW script I saw. Just occurred to me, my uncle has one as well.
