Technical 32 five window, need a few measurements
Discussion in 'Traditional Hot Rods' started by steve185, Jan 29, 2014.
  1. steve185
    steve185
    I am hoping someone can help me out with a few measurements on my 32, five window coupe. Right now the floor is gone, leaving the body a little wobbly.
    I am looking for the distance for the center of the outer, lower hinge bolt hole on the right side to the left, outer, lower hinge bolt hole.
    Also, the distance from center of the lower bolt hole on the door striker plate on the right side to the center of the same hole on the left side.
    And lastly for now, the distance from the center of a bolt hole on the left rear inner fender( hole closest to the front of the car) to the center of the same hole on the right.
    If anyone could give me these it would be a big help, thanks
    Steve
    29EHV8 likes this.
  2. steve185
    steve185
    I will bump this up to see if the evening crowd might be able to help.
    Thanks
  3. Andy
    Andy
    Too cold and dark for me tonight. I will try tomorrow.
  4. T&A Flathead
    T&A Flathead
    If Andy doesn't get it by then I can get it Friday.
  5. Old Tin and New Tin
    Old Tin and New Tin
    I come up with following:
    "A" pillar door hinge screw center is 42 3/4"
    "B" pillar dovetail screw center is 49 3/4"
    Sorry I can't give you the wheel well fender cage nut
    as trunk is finished and can't access for that dimension.
  6. steve185
    steve185
    Thanks so much Old Tin, I will be out in the garage tomorrow to fab a few supports.
  7. big duece
    big duece
    from kansas
    Mine is;
    Lower door hinge outboard screw 42 1/4
    Lower striker screw 48 13/16
    I have put a new floor in, but may not be exactly where Ford put it originally. But, everything fits right now so that where its stayin!
    29EHV8 likes this.
