Projects Model A
Discussion in 'The Hokey Ass Message Board' started by pennafxu, Nov 9, 2010.
  1. daddio211
    daddio211
    Dude, with your skills and abilities just BUILD a new ch***is. Use 1 1/2" x 3" or 4" rectangular tubing and go for it! You'll have a MUCH stronger frame and it'll be a lot less work than manipulating 80 year old stressed and brittle steel!
    Go back and look at how my buddy Bob built mine for some inspiration.
  2. Pensive Scribe
    Pensive Scribe
    What he said^^^^^ It's not rocket science. No regrets that way.
  3. pennafxu
    pennafxu
    from Kentucky
    Point well taken...
    However I am trying to utilize as much Henry as possible on this (and my frame albeit old) is in excellent shape. I just don't wish to re-invent the wheel and wish to use simple solutions that may be a little easier... This project is pulling on 3-4 yrs now! Wanna be driving it this summer as I have no other projects in the way... So the questions still stand minus the answer you have alluded to. (Sorry I'm a stubborn *******!)
  4. pennafxu
    pennafxu
    from Kentucky
    Noted see above please!
  5. Jeez! I hope your *** heals up soon! Welcome!
  6. pennafxu
    pennafxu
    from Kentucky
    Lol
  7. pennafxu
    pennafxu
    from Kentucky
    Bigs mounted... Need to unload em' and mock up the rear end... ImageUploadedByH.A.M.B.1389905822.975945.jpg
  8. pennafxu
    pennafxu
    from Kentucky
    Got the wheels mounted today... ImageUploadedByH.A.M.B.1391030900.547263.jpg
  9. pennafxu
    pennafxu
    from Kentucky
  10. pennafxu
    pennafxu
    from Kentucky
    Errr... Got some stance issues!
  11. pennafxu
    pennafxu
    from Kentucky
    Thinking as I was taking this about the rear z...
  12. pennafxu
    pennafxu
    from Kentucky
    Stock A front end 28-31 no drop...
  13. pennafxu
    pennafxu
    from Kentucky
    Question on the front end here... Will the engine/trans weight along with the 4" dropped axle get the job done, or do I need a reverse eye spring also to improve my stance issue?
  14. pennafxu
    pennafxu
    from Kentucky
    What kind of movement can I get out of these rear bones? I see them usually mounted on the transaxle cover... They seem to be pretty immobile? ImageUploadedByH.A.M.B.1391031840.401436.jpg ImageUploadedByH.A.M.B.1391031852.692449.jpg ImageUploadedByH.A.M.B.1391031866.236477.jpg
  15. daddio211
    daddio211
    It'll come down quite a bit with the weight. A reversed eye spring will drop it another inch, so I'd wait until you're almost done before you make that decision. Chances are you'll want it down another inch though.
    My '27 T Roadster build: www.jalopyjournal.com/forum/showthread.php?t= 734383
  16. daddio211
    daddio211
  17. pennafxu
    pennafxu
    from Kentucky
    Ok cool! Thanks for the response... I'm gonna send my axle to a guy named joe at joes speed shop... Around ur way! He will stretch drop it 4"
  18. pennafxu
    pennafxu
    from Kentucky
    Ok so they will mount to the side of the frame?
  19. TexA
    TexA
    I gotta agree,
    that grill would look a whole lot better on a "Binder" !
    Cool car though ;)
  20. daddio211
    daddio211
    Yep. This should give you a rough idea.
    Don't change or shim where your bones mount to the backing plates, let the front ends just end up where they do naturally, then build the mounts to them. Be sure to configure your rear axle with the proper pinion angle.
  21. alchemy
    alchemy
    Do a search on "Splitting rear wishbones" and you will get lots of opinions on both sides of the issue. The reasonable guys will tell you that they should not be split, but should mount together at the front. The guys with a death wish will say split them out to the frame rails.
  22. pennafxu
    pennafxu
    from Kentucky
    Ok that's the info I needed... Thanks man!
  23. pennafxu
    pennafxu
    from Kentucky
    Yeah cool thanks... Gonna mount em un-split on the bell housing...
  24. manyolcars
    manyolcars
    I agree. I used a Heim joint and mounted it as close as possible to the original location. The rear wish bones you posted wrapped around the axle when I put it in gear at idle. I tried again with the same results and had to make ladder bars. I used black pipe and have subjected them to incredible loads with no problem
  25. manyolcars
    manyolcars
    Bell housing? no front to bellhousing, rear are nowhere close
    transaxle?? (from your other post) We dont have transaxles in the old Ford world
  26. pennafxu
    pennafxu
    from Kentucky
    Sorry let me clarify... My nomenclature is all over the place... And I didn't understand the reference to the "rear split bones" until a minute ago, as I was confused with the front wishbone. I intend to not split the front wishbone and mount it under the bellhousing of the flathead or there abouts... The reference post above clarifies that I need to mount these rear bones to what I mistakenly referred to as a "transaxle" which I meant to say the tube that covers the drive shaft... That is what lead to my initial question of how can I maneuver these bones to the middle of the frame??
  27. daddio211
    daddio211
    You may have some clearance issues with an un-split front. Hopefully someone will chime in with more knowledge than me.
    Regarding the rear bones, like Alchemy said, there are arguments on both sides of the fence on this. I am partial to playing it as safe as possible but that didn't jive with the look I wanted. Therefore, Bob made another set of bars that attach to the inside of the split bones to give it more strength. If there were room to make it more like a four bar with upper links that would have been better yet.
    Always err on the side of safety.
  28. manyolcars
    manyolcars
    That tube is the torque tube. I have an open driveshaft so
    I attached my rear wishbones to a transmission crossmember using a very large Heim joint. The rear wishbones wrapped around the rear axle when I put the transmission in gear *at IDLE*. I had to make ladder bars which have been seriously overloaded but have held up
  29. pennafxu
    pennafxu
    from Kentucky
    Thanks... so bulk up the strength of the mounts...
  30. pennafxu
    pennafxu
    from Kentucky
    Hmmm... Ladder bars? Will read up on them... In the meantime started some grinding. ImageUploadedByH.A.M.B.1391218641.712953.jpg
