Let's see some sheet metal shaping
Discussion in 'The Hokey Ass Message Board' started by jhnarial, Sep 16, 2008.
  1. MP&C
    MP&C
    Well tonight's task was to remove the bottom detail of the lift gate and sandblast the remaining structure in prep for epoxy primer. The lower edge did have a flange folded up, so a slit was cut along the edge and the door skin vise grips were put to use...
    Next, the spot welds inside were ground out.....
    Media blasting..... nice to finally see through the gl***!
    The media blasting revealed a few more holes, and numerous pits, many of them close to breaking through.
    With all the other new metal going in the bottom, there's only one thing to do. Using the tipping wheel..........
    Comparing to the pitted version.....
    Next we'll need to do some corking to add the trim hole pad details.
    Rastus likes this.
  2. MP&C
    MP&C
    Now to address the mounting pads for the window molding....
    Here's the new "anvil", made from some phenolic sheet.....
    Put an alignment mark on the anvil, fitted it to the originals, and added the mark there as well. Then transposed those marks to the new piece...
    Anvil was located, and clamped in the vise to hold it's location
    Started with the barrel end hammer.....
    For the ends, I used a rounded tip chisel....
    ....and then another "anvil" to clean up the hammer marks a bit...
    Here's all the tools used....
    Touched up a bit with a sanding disc, looks close enough.... One down, 4 to go...
    Rastus likes this.
  3. NONHOG
    NONHOG
  4. MP&C
    MP&C
    Not sure which grade it is, I picked up this partial sheet about 25 years ago, was being thrown away. Looking at the prices on the link you posted, I'm glad I didn't leave it! :eek:
  5. bjinatj
    bjinatj
    Great pics and info, thanks for sharing..
  6. tltony
    tltony
    from El Cajon
    Here's an air dam we made for a 67 Camaro. It'll be used only on the track, as it's removable with 1/4 turn fasteners
  7. heyitsnate
    heyitsnate
  8. niceguyede
    niceguyede
    from dallas
    That's a handy little *******!
    Sent from my LG-P769 using H.A.M.B. mobile app
  9. MP&C
    MP&C
    Last night I worked to finish up the pad details on the inner structure of the lift gate.... The center one was wider, so I used the same phenolic and just added a wider detail to the opposite side. I missed showing this earlier, but a handy-dandy battery saw works well to remove the bulk of the material, sawing parallel cuts and then just working the saw side to side to clear out the remaining....
    Once cut out, the sanding disc is used to cut down the angled sides and touch up the bottom..
    This compares the two, showing the difference in width...
    Alignment marks transposed from the original, and guide marks indicate the area in need of hammering...
    I had a request to show the hammering procedure, so here's another video attempt. The first one is using the phenolic anvil clamped against the work piece in the vise, the second uses 1" square stock as an anvil to clean up the hammer marks a bit...
    http://s5.photobucket.com/user/rmcc...y Wagon Restoration Album 3/Video232.mp4.html
    http://s5.photobucket.com/user/rmcc...y Wagon Restoration Album 3/Video233.mp4.html
    ...also sounds like I have a loose hammer handle, something for another day.... ;)
    Then the sanding disc was used for final cleanup. Here's the finished piece, just needs a couple holes drilled....
    Rastus likes this.
  10. MP&C
    MP&C
    Some re-***embly....
  11. 36 ROKIT
    36 ROKIT
    Wow; nicely done!
  12. whtbaron
    whtbaron
    from manitoba
    What are you using for media? I've been seriously looking at those sales on soda blasters from Eastwood. They seem to come up on a regular basis, and I've got an old metal hopper that might become my blasting cabinet some day. I'm beginning to think you're wasting time recreating other car parts... it might be faster to just make your own car from scratch! You've got some great talent there. I've tried enough to know it's nowhere as easy as you make it look.
  13. MP&C
    MP&C
    I'm using this stuff:
    Here's what it looks like, along with a few strays of Black Beauty.
    Rastus likes this.
  14. whtbaron
    whtbaron
    from manitoba
  15. BarryA
    BarryA
    RHD '64 Impala's apparently used a Pontiac dashboard - we were asked to scratchbuild a RHD version of an SS dashboard (with some mods)......kicked my *** for a while but got it done eventually. Budget constraints meant I didn't take this to a full metal finished state....
    Rastus likes this.
  16. Very nice work BarryA!!
  17. hasty
    hasty
    Thats impressive, Barry A
  18. niceguyede
    niceguyede
    from dallas
    Putting some 39 ford tails in a 60's Chevy stepside. I had to extend the fenders a couple inches at the bodyline to make it look right. The first fender I had to do in 4 pieces. The second one I got in 2. Those double reverse curves are a mother to do by hand.
    Rastus likes this.
  19. BarryA
    BarryA
    Cheers Hasty, Laidout.
    Niceguy that's some nice work!
  20. biggeorge
    biggeorge
    That Looks great. nice work
  21. bjinatj
    bjinatj
    Wow, very cool Barry..
  22. fleet-master
    fleet-master
    you guys are doing some great work!! thought I'd chip in again with a few pics of some work I did on a 64 Falcon coupe. The poor thing had been in the wars ...best thing to do was cut the old sections out and start again with fresh metal..20 guage zintec
    old..
    new...
    it was quite tricky with the upper line having a gentle curve in it from front to rear...
    but it actually came out pretty good and required only around a cup full of filler to finish off before paint.
    Rastus likes this.
  23. oztinbasher
    oztinbasher
    from oz
    Here's a bus I just finished hand made guards,and all the shaped panels.
    Cheers Steve
    Rastus and waynos like this.
  24. Rods & Relics
    Rods & Relics
    Who's been a busy boy then :D:D
  25. NONHOG
    NONHOG
    Very cool! what gauge did you use?
    Awesome!
    In awe!
    Those inner shrink marks, how did you do that?
    Cool rig!
  26. Rods & Relics
    Rods & Relics
    I would have said, with Thumb Nail dies ;)
    (I love mine :D)
    Rastus likes this.
  27. big_dan
    big_dan
    from Tennessee
    Wow. Some serious talent on here using some serious machines!
    Might as well throw my hat in the ring so here goes. Here's a hand made 64 Comet lower quarter I did a year or so ago - before:eek: and after:D. No pro but pleased with the results.
    Dan
  28. Rods & Relics
    Rods & Relics
    Cool Dan :D
    It's all about having a go ;)
    (some of us only "pretend" to be pro's :eek:)
  29. Rods & Relics
    Rods & Relics
    I ran them in raw steel for about a year until I finally found the time to throw a bit of paint on them.
    My old girl has been a daily driver for around 10 years, so it's always a "work in progess" lucky the local coppas know me, at one stage I only had one fender on, then 2 then 3 & finally the 4th after about 6 months :eek:
