Bbc motor mounts for model a frame?
Discussion in 'The Hokey Ass Message Board' started by Wildbill29tudor, Jan 30, 2014.
  1. Wildbill29tudor
    Wildbill29tudor
    What are the best mounts to use when mounting my big block Chevy in a model a frame?
  2. gimpyshotrods
    gimpyshotrods
    Sturdy hand-made ones, that attach to the boxing plates, and another frame surface (2-plain attachment).
  3. Wildbill29tudor
    Wildbill29tudor
    Any pics?
  4. 1971BB427
    1971BB427
    from Oregon
    Here's a picture of the Speedway mount that would work well:
    http://www.speedwaymotors.com/1965-1994-Big-Block-Chevy-396-454-Engine-Mount,6726.html
    You will need to buy or fabricate a frame mount for it to sit on, and also use the rubber cushions between frame mount and engine mount:
    http://www.speedwaymotors.com/1928-1934-Ford-Frame-Adapters,77.html
    http://www.speedwaymotors.com/Universal-Bolt-Through-Engine-Mount-Cushion-Kit,1199.html
  5. gimpyshotrods
    gimpyshotrods
    That BBC is going to put a hell of a load on an aluminum bell housing, or transmission case, with just a front monunt.
    Given the weight of the car, unless he's running slicks, the rear tires will spin, well before he can break something.
  6. rotten johnny
    rotten johnny
    from Mi
    Made mine from 1-5/8 mild steel
  7. gimpyshotrods
    gimpyshotrods
    Note: R J has installed a mid-mount plate, between the engine and transmission.
  8. madmak95
    madmak95
    Very interesting ch***is..... lot of set back.... whats it for ?
  9. 1971BB427
    1971BB427
    from Oregon
    Yes, going with a BBC I'd want a mid bellhousing plate or mounts, even if it had side mounts. Wouldn't be an issue if the bell was a steel ****tershield, but as you mentioned an aluminum wont handle much weight and HP.
    These mid mounts make a good alternative to a full mid plate.
    http://www.speedwaymotors.com/Steel-Rear-Motor-Mounts-Chevy,3278.html
