Belt Squeal after alt swap on Y-block
Discussion in 'The Hokey Ass Message Board' started by iFlip, Feb 2, 2014.
  1. iFlip
    iFlip
    from San Angelo
    I've gotten 500 different anwers for this so i'm hoping you guys can help. Used the Alternator conversion kit from Concours parts, and it squeals really bad now. It's just a 1-wire GM alternator. Does it sound right that they pulley could be too deep for it? We had to roll the belt onto the pulley so I don't think a shorter belt could be put on, and it's all lined up right. Do ya'll think a shallower pulley could help solve it? Really appreciate input.
    Pic of pulley for reference
  2. sport fury
    sport fury
    looks like the v belt is bottoming out in the alternator pulley. the belt needs to wedge it self in to pulley without bottoming out to grip enough
  3. sport fury
    sport fury
    wrong or worn belt or pulley
  4. iFlip
    iFlip
    from San Angelo
    Used a laser to check them.
    Forgot to say you can spin the alt pulley when the belt is on it, has some resistance to it though.
  5. sport fury
    sport fury
    i really like the idea of using a laser to check pulley and belt alignment. especially while engine is running.
  6. Engine man
    Engine man
    from Wisconsin
    Looks like you need a narrower pulley or a wider belt. How much of the pulley does the belt contact? It needs to contact at least on third of the surface of the pulley. A cogged belt can help get more grip.
  7. Engine man
    Engine man
    from Wisconsin
    If you can turn the alternator fan by hand, the belt is too loose or not getting a grip on the pulley.
  8. Mike Moreau
    Mike Moreau
    Look at your crank pulley as well. You should see "shiny" on the sides of the "V" and no shiny on the bottom. Check the water pump & any idlers as well. If you are satisfied with the contact area and location on the crank/water pump/idler pulleys, change the alternator pulley to match the "V" of the others. If all your pulleys have evidence of contact on the bottom, go to a wider "V" on the belt. Your pic was worth a 1000 words, as they say.
  9. txturbo
    txturbo
    compare the width of that alternator pulley to the other pulleys on the motor. Looks like you have a wide groove pulley and you are using a narrow belt. The belt will slip if it bottoms out in the groove like that one is.
  10. Kiwi 4d
    Kiwi 4d
    Fold the belt in half and lay it in the pulley so you can see underneath the belt to get an accurate idea of pulley to belt contact.
  11. hoop98
    hoop98
    from Texas
  12. iFlip
    iFlip
    from San Angelo
    Water pump pulley
    Alt with the belt on it
    Water pump with belt
    Would say the alt pulley is too wide yeah? Thanks for the help so far guys.
  13. tfeverfred
    tfeverfred
    Swap out the pulley. You can see it's too wide in the photo.
  14. Super Streak
    Super Streak
    from Florida
    That alternator pulley is NFG, it is to wide. You need to get one that is the same or near to the same width as the water pump pulley.
  15. clem
    clem
    As per posts 14 & 15. Pulley is too wide. Other reasons sometimes can be belt tension incorrect, and I've even heard them squeal just because the belt is new.
  16. iFlip
    iFlip
    from San Angelo
    Little update, got the new pulley put on and it no longer squeels. Thanks a ton guys.:D
  17. McGurk
    McGurk
    from Mid West
    Show a picture of the original Y-Block pulleys. It appears to me that your belt is too wide for the late model pulley. The burnt rubber is too high in the grove.
    McGurk
  18. hoop98
    hoop98
    from Texas
    The belt is bottomed out because the pulley is too wide. The shiny part is where the belt is slipping.
