some of the work from my shop
Discussion in 'The Hokey Ass Message Board' started by cornfieldcustoms, Nov 15, 2011.
  1. cornfieldcustoms
    cornfieldcustoms
    the owner of the ch***is dropped off some parts yesterday, so today i started back in on the ch***is
    got the engine set up on the table, centered and the front at a height i like.
    then designed and cut out some new block side engine mounts. still need to cut and weld on the side gussets
    i made a shock mount bar for the ch***is and got the shocks in
    started laying out the design for the tube k member as well
  2. cornfieldcustoms
    cornfieldcustoms
    more progress
    tube k member all bent up, notched and tacked in
    got the frame side of the motor mounts cut, bent and tacked in
    cut bent and tacked in the trans mount and x member
    cut and dimpled some gussets for the hair pins to help stiffen them up some
    motor and trans pulled back out to finish weld and dress the frame
  3. Johnboy34
    Johnboy34
    from Seattle,Wa
    Your work looks super, bending the tubes sure came out nice. Mabey I missed something or will the trans crossmember be removable?
  4. cornfieldcustoms
    cornfieldcustoms
    thanks man, on this ch***is the trans x member will not be removable
  5. lrs30
    lrs30
    from Kentucky
    Looks killer mike, really knocking them out! I will touch base with you about the things we talked about! Going down tomorrow to pick up that new project! Sorry to hi jack lol keep up the killer work man!
  6. cornfieldcustoms
    cornfieldcustoms
    got the ch***is all welded up, and on the ground. put the plywood wheels on to see how it looked
    and tagged the frame
  7. wade57
    wade57
    from BC Canada
    You do very nice work
  8. woodbutcher
    woodbutcher
    :D:eek:Absolutely outstanding.Please keep the updates and pics coming.
    Good luck.Have fun.Be safe.
    Leo
  9. 59ab
    59ab
    High quality work!
  10. MP&C
    MP&C
    Looking good Mike!
  11. wide34
    wide34
    from Texas
    Met Mike at one of the Baileigh cl***es where he was teaching, great guy to talk with and willing to help anyway he could. Obviously his work speaks for itself!
  12. cornfieldcustoms
    cornfieldcustoms
    been a busy couple weeks with all the work going on in the shop with customer cars and spent 4 days in Indianapolis for the world of wheels. i devoted a little bit of time to design and cut out some brackets and tabs on the cnc plasma to sell all of these brackets and tabs are universal tabs. they can be used for just about anything from shock tabs, 4 link tabs, body mounts, or anything else you want to use them for. all of them are 3/16 mild steel with a 1/2 inch hole but can be ordered with different specs.
    sorry that some of the pics are upside down or sideways. i rotated them in photo bucket but come up on the board wrong. but you can get the idea
    these are a folding tab that work perfect for body or bed mounts but can also be used for any other applications fold the sides down to where you need them and weld up the cut
    and these were custom ordered brackets by a customer for some proto typing parts for later model pedal conversions
  13. summersshow
    summersshow
    from NC
    I wish I had a cnc plasma :( sweet stuff man. nice work
  14. cornfieldcustoms
    cornfieldcustoms
    nothing to amazing going on lately, but here are a few cool things i have been working on, on the Baileigh CNC plasma table
    a couple signs for a buddies birthday
    rear ladder bar and lower 4 link mounts
    some flanges i like to use on removable cross members used with 1.75 round tube
    and some 33-34 boxing plate. i also have some 32 plates but didnt snap a pic
    and lastly i have been getting my 47 sedan ready for spring with a few changes to its looks from last year
  15. lrs30
    lrs30
    from Kentucky
    I dig the speed hole mounts! Looking good man!
  16. cornfieldcustoms
    cornfieldcustoms
    the past couple days i have been back on the 57 retractable. lots of fun metal shaping lol
    this is what the tail light surround mounting area looked like before, i forgot to snap a pic before i started
    after cutting out all the bad areas to make room to work, i cut out some rings on the plasma table to match the back of the tail light housing, and tacked them to the body using the bezel as a guide
    after the ring was tacked in, reinstalled the bezel and made a paper template to aid in layout of shrinks and stretchs and give me the basic size and shape of the material needed
    after a good long while of shrinking, stretching, wheeling and hammering i have a pretty good looking patch. doesnt look like much but there is a ton going on in this little area, a tapered reverse compound curve
    marked, and cut out for new patch to be **** welded in
    after all the welding and grinding this is what i had, still needs some attention. but at this point there has been no hammer and dollie work done just welding and grinding
    then moved on to the lower area
    and the finished product
    now onto more damage
  17. MP&C
    MP&C
    Awesome repair Mike!
  18. rockable
    rockable
    Wow. "Doesn't look like a lot going on here".....but those of us who have tried to make a piece like that know differently. Great job!
  19. fordf1trucknut
    fordf1trucknut
    Awesome work!!!!!!!
  20. AHotRod
    AHotRod
    Great craftsmanship! Well done.
  21. cornfieldcustoms
    cornfieldcustoms
    more work on the retractable. the rear pan area around the license plate had been frenched...... well kind of. so all the needed to be replaced back to the stock look
    started shaping the panel on the e wheel. the rear panel looks pretty flat but there is a little bit of a compound curve in the center. with the straight edge you can see the crown
    then added the roll and two breaks to the bottom end of the panel
    then stripped the paint and filler stripped around the area and prayed some ****m
    cleco'd the panel to the car to scribe the cut line.
    all ready to cut out first thing in the morning
  22. Rust n' Chrome 99
    Rust n' Chrome 99
    looks proper mike, always love seeing metal work. never gets boring to me.
  23. Hot Rod Bob
    Hot Rod Bob
    from T-ville Ky
  24. dondogarage
    dondogarage
    from richmond
  25. cornfieldcustoms
    cornfieldcustoms
    more progress on the 57
    the rear patch all welded in and ground down
    had to cut the bracing out behind the panel to get at the back of the welds for some hammer dollie work
    after the hammer and dollie it was time to break out the shrinking disc to smooth her out
    rear bracing welded back in
    all ground down and some primer added
    rear panel finished up
    found some more rust, out with the bad
    in with the new
  26. cornfieldcustoms
    cornfieldcustoms
    so now it was time to tackle the inner wheel well so i could move onto the quarter panel repairs
    trimmed out more of the damaged area that needed replaced, which also helped make room to repair all the damage on the inner wheel well itself
    clamped the quarter patches on to make a cardboard template of the wheel well opening
    then transferred the cardboard pattern to 3/4 inch plywood to make a hammer form
    wheel lip hammered out and fulled from the form
    after some shaping, bead rolling and t******* it is test fit into the car
    then edges cut and tacked in
    fully welded then ground smooth
    quarter patches clamped back on to make sure nothing moved, and to get a game plan on the next steps to repair the quarter panels where the new stampings dont reach
  27. MP&C
    MP&C
    Pretty slick Mike, thanks for posting!
  28. 56effie
    56effie
    Mad Skills in that shop... Great work..
  29. cornfieldcustoms
    cornfieldcustoms
    more progress on this one.
    made a patch and got it tacked in to repair the radiused area of the quarter panel
    then fit and welded solid the rear corner of the quarter
    then we are left with this nice little gap
    formed a little filler piece and clamped it in place
    tacking it up just to the lower quarter, that way i can weld it solid to the quarter patch, pull it off and metal work it before welding the entire lower quarter on
  30. nhmikel
    nhmikel
    from NH
    Hi Mike
    ???? What did you do or should you with the bare metal inner before welding
    on the outer skin?
    What is done to protect the inner and back side of outer from rusting?
    Sweet work good job metal shaping
