Tapping dom
Discussion in 'The Hokey Ass Message Board' started by lakesmod, Feb 3, 2014.
  1. lakesmod
    lakesmod
    I need to tap a hole in dom tubing for a 5/8-18 rod end.
    The drill for this size is 37/64.
    I have a 9/16 drill,that is a 1/16 smaller then the 37/64.
    Will the 9/16 drill work?
  2. 66tintop
    66tintop
    from Canada
    Not a chance , with fine threads , it going to be tight !
  3. use the correct size drill
  4. Hnstray
    Hnstray
    from Quincy, IL
    There are two diameters involved in a thread, the minor and major. The drill size specified for a particular thread diameter and pitch is the smaller of the two. The tap then cuts threads to the larger of the two. The tap has no ability to INCREASE the size of the bore.....only to cut threads in the CORRECT size bore.
    Buy the correct tap and save yourself time and GRIEF!
  5. nmpontiac
    nmpontiac
    from Taos, NM
    Most tap specs are for 75% threads and as such they really need to be drilled to the spec'd size. I think you'd have a hard time getting that thread cut correctly without the right size drill.
  6. banginona40
    banginona40
    Try it on a piece of scrap just to see.
  7. Bert Kollar
    Bert Kollar
    I tried it and the tap broke in half
  8. jimvette59
    jimvette59
  9. Paul
    Paul
    Editor
    It's actually only 1/64" smaller but, you should still get the correct size drill bit.
  10. fsae0607
    fsae0607
    Get the right bit.
    A good hardware store or even HF will have it in a set.
  11. 17dodgebros
    17dodgebros
    u will break the tap
  12. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Good luck finding a 37/64" drill bit at HF. Its not really a standard size found everywhere.
  13. McGurk
    McGurk
    from Mid West
    Thread taps are not designed to cut on the minor diameter so if you were able to start the tap then is would eventually become a press fit in the under size pilot hole and the tap would seize.
  14. Buy, borrow, or steal the correct bit!
  15. john walker
    john walker
    go to a machine shop that has the ability to put 2.5" of thread depth in that tube. you ain't going to have much luck by hand. they will have a quality tap that won't break off too.
  16. fsae0607
    fsae0607
    ^^ oh damn just noticed it was over 1/2" diameter. My bad.
    OP, Maybe try a hardware store that sells the tap & tap drill as a set, or McMaster-Carr?
  17. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Why not? Ive been doing it for years, well over 1000 holes, never broke a tap. Most guys that make their own RR and steering drags have as well.
  18. Firecat7
    Firecat7
    Always use tap fluid (oil).....and no tranny fluid is not tap fluid, neither is motor oil, hydraulic fluid, rhinocheros sperm ,or anything except tap fluid!......are you hand taping? Or lathe? Critical to be absolutely straight!.....drill cant be all that expensive.....ya beg borrow or steal, oh and get the tap fluid too.:)
  19. lakesmod
    lakesmod
    I did this 12 years ago on another project and have the right hand and left hand taps.
    I just couldn't find the 37/64 drill that is the reason for my question about a 9/16 drill.
    After looking where I never would have put it ,it has been found.
    I will drill with my H F 16 speed drill press and hand tap it.
    When I did this 12 years ago a machinist made a tool it start the tap straight and I still have that.
    Thanks for all the replays.
