What bellhousing for a t-5 to Chevy ok banger
Discussion in 'The Hokey Ass Message Board' started by willbierfarms, Feb 3, 2014.
  1. willbierfarms
    willbierfarms
    from palmyra mo
    Which bellhousing do I need for putting a t-5 behind a Chevy ii banger? I was told the firebird and camaro tilt the trans I know the banger is the same bolt pattern as a sbc but I'm so gm illiterate I'm at a loss trying to find it
  2. nailheadroadster
    nailheadroadster
    Depends on the T5. Is it a 14 or 26 spline input shaft?
  3. willbierfarms
    willbierfarms
    from palmyra mo
    14 spline
  4. nailheadroadster
    nailheadroadster
    I am not familiar with the Chevy 2 banger so I gotta take your word that it matches an sbc. But... if that is the case... a Muncie 4 speed bellhousing will be what you need. Either steel or aluminum.
    Drill the mounting holes on the gearbox case to1/2". Bolt it up to the bellhousing. Test fit onto the banger without the clutch. Do not tighten it down until you are 100% sure that the input shaft does not bottom out on the end of the crankshaft. If it does bottom out before the bellhousing is tight to the block, trim the end of the input shaft accordingly. Test fit again until the clearance is correct. Be damn sure it isnt hitting the crank before tightening it down or you could break an ear off the aluminum gearbox.
  5. A T5 has the basic Chevrolet bolt pattern, it will bolt on using the stock bellhousing. The ******s that tilt to the drivers side have Ford bolt patterns and , you don't wanna use those.
    Everythibg you ever wanted to know about T5 is here: http://www.jalopyjournal.com/forum/showthread.php?t=169265
