35-36 Ford Drive Shaft Lake-Headers
Discussion in 'The Hokey Ass Message Board' started by 343w, Feb 3, 2014.
  1. 343w
    343w
    Can someone tell me when using the inner driveshaft for lake type headers, do you cut one shaft in half to make the set, or does it take two shafts? I am looking to end up with the typical looking headers that are from back in the 40's.
  2. 42merc
    42merc
    One shaft cut in two equal pieces.
  3. 343w
    343w
    That will make it much easier to accomplish!
  4. rollingbones 1
    rollingbones 1
    from UPSTATE NY
    The 35-36 drive shaft is tapered on both ends. Cut off the splined ends,& then cut the tapered tube in half. You now have perfect lake pipes.
    The picture above is the torque tube, not the driveshaft.
  5. 4 banger 4 life
    4 banger 4 life
    from ohio
    1935-6 are the ones to use. woops too slow...
  6. 343w
    343w
    Thanks for the skinny on the driveshaft!
  7. stillrunners
    stillrunners
    from dallas
    and I didn't know that....thanks....
  8. barnfind08
    barnfind08
    from minnesota
    I wanted them longer so I used 2 driveshafts. I guess I would make a sample with something like Plumbing 4" plastic pipe from home depot before cutting up the hard to find driveshafts.
  9. I got me the best pair. They're angle cut and made by Gene Winfield back in the day. My most prized possession. :D
  10. wutnxt
    wutnxt
    The steel in these things is superb, they make awsome tailpipes and produce great sound. Once you cut one in half, hold it loosely in your hand and tap it with a wrench. Yuo'll se what I mean.
  11. I like them longer so they don't look so generic...
