does this look right to you
Discussion in 'The Hokey Ass Message Board' started by harleynut45, Feb 4, 2014.
  1. harleynut45
    harleynut45
    Just got a ****** adapter from a supplier. When I opened the box I noticed the one drilled and tapped hole is awfully close to the edge. Thoughts?
      247.4 KB
  2. patmanta
    patmanta
    from Woburn, MA
    That does not look right to me. Not at all. You should have the width of the hole to the edge as a general rule as I understand it. I wouldn't run that, I'd be on the phone with the supplier.
  3. primerhotrod
    primerhotrod
    from ILLINOIS
  4. Merlin
    Merlin
    from Inman, SC
    +1
  5. FrozenMerc
    FrozenMerc
    Exactly, at least 1 hole diameter from the edge to the center of the hole, better to be 1.5 or 2 hole diameters in cast aluminum. The supplier probably just had it mounted crooked in the machining fixture. Send it back and ask for a new one.
  6. choppedtudor
    choppedtudor
    yeah, quality control is now in the hands of the consumer. sad, but true.
  7. If it was a single hole holding something to a chunk of aluminum I'd be concerned but seeing that it has 4 tapped holes and the transmission registers in the center I would move on. Let the seller know in case it creates a problem later.
    I would, however, slip a trans on there and make sure everything lines up.
    Charlie
  8. TagMan
    TagMan
    Absolutely, send it back !
  9. Fenders
    Fenders
    I suppose you could see whether your ****** mount holes line up with all the holes on the adapter -- my guess is it won't.
    In any case I would return it.
  10. propwash
    propwash
    from Las Vegas
    Excellent advice, better to be inconvenienced by waiting for your replacement than to be inconvenienced when you're in your coveralls, under the car with the ****** out and then find out it doesn't fit (after several attempts).
  11. my47buicksuper
    my47buicksuper
    from sunny fl.
    Frozenmerc is correct send it back and ask for a discount since they inconvenienced you
  12. exactly, doesnt look like it would even be able to bolt up.
  13. 28TUDOR
    28TUDOR
    X's 2
  14. harleynut45
    harleynut45
    Thanks Guys......that's my opinion to. It's going BACK. Hopefully there's no h***le about shipping cost
  15. hotroddon
    hotroddon
    I think before I sent it back I would talk to the supplier. I would also check to see if there is a reason that it needs to be that close to the edge, as in something doesn't allow it to have a larger ear there.
    Does it bolt up to the transmission?
  16. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    I wouldnt accept that for my car, even if it did fit. That looks like dimpled ***.
  17. phat rat
    phat rat
    Look again, that hole is partially covered by paper
  18. lothiandon1940
    lothiandon1940
    ........Wow. You're right, It sure did look bogus at first glance.:eek:
  19. hotroddon
    hotroddon
    So it is - Thanks. couldn't see that until I blew it up :)
  20. norcal rizzo
    norcal rizzo
    Yeah, id send it back, if they tell you its good, then find another supplier, theres no strength for that thread. If its not refundable, then maybe thread a br*** bolt in there and have a good welder build up the outside, run a roll-tap into it to reform the thread, then check the faces for flatness.
    the metric system? never heard of it.......
  21. MAD 034
    MAD 034
    from Washington
    Not right -- give 'em a call and tell them its coming back.
  22. harleynut45
    harleynut45
    TRUST ME, there is no PAPER, TAPE, or anything else anywhere near that hole
      257.6 KB
      174.8 KB
  23. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    He was talking about the hole at the bottom right corner of the pic.
  24. harleynut45
    harleynut45
    Yeah, that's the newspaper it was packed in. that hole is ok
  25. harleynut45
    harleynut45
  26. hotroddon
    hotroddon
    Again - Does it Fit the Transmission????????????????
  27. harleynut45
    harleynut45
    ****** not here yet. It's on its way (T5)
  28. Before everyone gets too excited, how deep is the hole? And is it actually in the right place?
    If the location is correct, can the hole be drilled/tapped deeper? If I could get 2 to 3" of thread engagement (or more) I don't think I'd be all that worried.
  29. Firecat7
    Firecat7
    SPEEDWAY??????:eek:
  30. harleynut45
    harleynut45
    Not Speedway. Not going to say who, till they have a chance to make good on it. Cant put it together yet anyhow...****** not here yet......and it's to damn cold in my detached garage....lol
