Projects *Tech Week* twin plug
Discussion in 'Traditional Hot Rods' started by nutrocker, Feb 5, 2014.
  1. nutrocker
    nutrocker
    I've always had this thing about twin plug heads on a flatty. To my eyes they look awesome, kind of form and function. But alas the down side has always been cost against the actual gains. Heads are big bucks and the usual Nash twin 8 dizzy's are well out of my price range.
    So this is what I did.
    I started with a pair of used Edelbrock script heads taken from my '30 A roadster, cleaned them up and set them on the pillar drill. First job was to drill through from the underside to line up with the centre of the piston.
    Once both heads were drilled through I set them on the mill and used the first hole as a guide to cut a 2" hole out of the outer face.
    Once all eight holes had been cut I machined a 3/4" hole through into the combustion then machined a flat face on the inside where it had uneven casting.
    Next bit was to take eight of these 2" slugs.
    Create this amount of swarf.
    To make eight of these.
    Because the heads taper towards the outer I then fly cut the tops to match.
    Time to weld in. In the pics it shows that I put a counter bore around the insert, but I didn't think it was enough so I made them deeper but didn't take any pics.
    Then pre heat the heads and weld the insides. The process was to run a deep root weld them cap.
    And the last bit for the heads was to use studs to bolt both heads together, heat the up and weld all eight of the outer part of the inserts.
    Just needed to leak test with a penetrating dye and bead blast.
    That's it for part one. Part two, making the extra plugs spark, to follow.
    Pete.
    kadillackid, KiWinUS, Stogy and 3 others like this.
  2. alchemy
    alchemy
    Wow!
    Stogy likes this.
  3. interesting...what are your plans for the ignition?
    Stogy likes this.
  4. nutrocker
    nutrocker
    Part two, ignition. Not having the cash for the Nash I decided to use two dizzy's. So starting with a couple of French flatty front covers I set about cutting and welding to create this.
    With the left hand head being further forward and not having a cut out for the dizzy clamp I needed to extend the dizzy shaft. For this I just made an extension complete with bush that will be roll pinned into place.
    And because the French cover has a larger hole I made an adaptor to locate the dizzy in the cover 1-3/4" further up.
    And in place.
    One thing I did have to do was cut the top mount off the water pump. At the moment it seems to be fine but if it causes a problem by leaking I'll make a clamp from one of the front cover bolts.
    And finally some pics of it all on the motor.
    Just now waiting for Bubba to finish converting some Chevy dizzy's and as soon as it arrives it's all ready to run.
    Hope you've found this of some interest.
    Pete
  5. choppedtudor
    choppedtudor
    I'd never thought of doing it THAT way...WOW. Can't wait to see your solution for making them spark.
    Stogy likes this.
  6. 4 banger 4 life
    4 banger 4 life
    from ohio
    Thats bad *** cool idea I love it....... thanks for sharing.......
    Stogy likes this.
  7. Crankhole
    Crankhole
    Holy Sh!t. Nice.
    Stogy likes this.
  8. prewarcars4me
    prewarcars4me
    from Bhc, AZ
    Simply amazing.
    Stogy likes this.
  9. +1 That's bad ***!
    Stogy likes this.
  10. Jethro
    Jethro
    I have a feeling you are going to see a lot of twin plug flatties in the coming months!
    Nice job!
    Outback and Stogy like this.
  11. RichFox
    RichFox
    Really nice. Here was my way on a banger
    Stogy, kidcampbell71 and slack like this.
  12. revkev6
    revkev6
    from ma
    Love it! I have thought of using a similar process to create an ohv conversion.
    Stogy likes this.
  13. RMR&C
    RMR&C
    from NW Montana
    Nice work! Do you have a pic of the underside of the head with spark plugs in the new holes? Wondering how far they reach in?
    Stogy likes this.
  14. daily_driver
    daily_driver
    Very cool. Gives me all kinds of ideas for some flat sixes I've got around. Where did you get those su adapters? Or are those some more custom machining work?-dd
    Stogy likes this.
  15. fastmike
    fastmike
    from Mesa AZ
    Wow! Very very impressive!
    Stogy likes this.
  16. 117harv
    117harv
    You hope we found this of interest? You're kidding right?:)
    Outstanding work, thanks for the taking the time to share with us...5 stars.
    Stogy and kidcampbell71 like this.
  17. pinkynoegg
    pinkynoegg
    now to go find an old pair of heads and make my own! this is awesome
    Stogy likes this.
  18. ago
    ago
    from pgh. pa.
    Love the carbs.
    Ago
    Stogy likes this.
  19. D-man313
    D-man313
    Wow, thats awesome!
    Stogy likes this.
  20. 3wLarry
    3wLarry
    from Owasso, Ok
    You and RichFox are insane...ain't it great?
    Outback, flatheadpete, Stogy and 2 others like this.
  21. bobbytnm
    bobbytnm
    Holy cow!
    This is amazing. Very nice work
  22. Saxman
    Saxman
    Ah, it ain't such a big deal, fellas. All you need is brains...and mad skills...and tools...and BALLS!! Okay, this is freakin' AMAZING. :D
    Stogy likes this.
  23. Speedy Canuck
    Speedy Canuck
    Wow. This is amazing tech! Very cool stuff.
    Posted via telegraph.
    Stogy likes this.
  24. cully33
    cully33
    Great work you have a lot of talent.
    Stogy likes this.
  25. Muttley
    Muttley
    Feel free to use this picture for your avatar:
    Outback and kidcampbell71 like this.
  26. Anymore pics?
  27. You're a very clever man, well done!!!!
  28. Corn coupe
    Corn coupe
    from CZ
  29. sawbuck
    sawbuck
    from 06492 ct
    I think we have a winner ..tech week..
