Projects What!!? another 27 on 32 chassis!??. Scratch build body.
Discussion in 'Traditional Hot Rods' started by Mindover, Jun 5, 2011.
  1. Mindover
    Mindover
    from England
    I laid it on the ch***is upside down so I could mark the shape of the crossmember onto it...
    when it is up the right way it will also be rotated 180 degrees.
    I used the pattern I made earlier to check it was the correct shape and mark out the flange.
    below is what it looked like with the flange formed using a hammer and bench dolly.
    Checked it with the pattern...
    David
  2. Mindover
    Mindover
    from England
    Next I cut out the side pieces from my patterns using my bandsaw, then I formed the bottom flange for these - again using a hammer and dolly...
    David
  3. Mindover
    Mindover
    from England
    Here are the parts ready to weld together, this is all 1/8th steel as per the original material used.
    David
  4. Rusty Karz
    Rusty Karz
    Nice work(as always). Thanks for taking the time to show us how you work this magic.
  5. 64 DODGE 440
    64 DODGE 440
    from so cal
    I appreciate the fact that you show folks what can be done with hand tools and a bit of perseverance. Good work David.
  6. Mindover
    Mindover
    from England
    Thanks for commenting guys. I was thinking about this last night after posting these photos and realised that I had made a ****-up. Nothing unresolvable but a bit of a pain. I will show more soon.
    David
  7. Gojeep
    Gojeep
    from Australia
    Be tough work bending the 1/8" thick steel when making the curved flange.
    Can you still get 1/8" there as here in Australia I can only get 3 mm?
  8. Mindover
    Mindover
    from England
    Its 3mm but most on here would not know what that is, its the nearest we can get to 1/8th whats 1/8th 3.25mm? pretty close.
    Forming the parts by hand is not too hard, I use a slightly heavier hammer but I don't have to put a huge amout of force behind it. If you go much thicker it starts to get tough though!.
    David.
  9. Mindover
    Mindover
    from England
    I will have to sort my mistake out before this is fitted to my ch***is but I will show where I am with it now.
    The parts I formed were tack welded together...
    Then fully welded inside and out...
    I used gas welding for this.
    The other side was then tacked and welded in the same way...
    With a good fillet of weld on the inside and the outer corner reduced to a radius by welding I could clean this up without making the metal thin.
    Once I had cleaned up the weld on the outside with a sander it looked like this...
    I have made this so that it will rivet in place like the original part would have. Pitty I made a mistake in the design but I will sort that out soon.
    David
  10. Nice work!
  11. Mindover
    Mindover
    from England
    Cheers Skatermann!.
    David
  12. 64 DODGE 440
    64 DODGE 440
    from so cal
    Nice to see someone can still weld with a torch. :D
  13. Mindover
    Mindover
    from England
    I got my first welding qualification in pipe and plate welding (gas and arc) in 1976 I can't remember the last time I gas welded anything other than thin sheet though so I am a bit out of practice.
    David
  14. mad mechanic
    mad mechanic
    Any more updates?
    following this very keenly
    Jay
  15. nzsimon
    nzsimon
    Wow very cool
  16. Mindover
    Mindover
    from England
    I had a bit of a mishap with my trans, one more thing to sort out. I will post an update asap.
    David
  17. Mindover
    Mindover
    from England
    Thank you.
    David
  18. mika112
    mika112
    Still and yet the work of silversmith .
  19. How goes it David???
  20. Mindover
    Mindover
    from England
    Hi Mike, I have been busy as hell. I have loads of work on and I have been trying to get the new bit if workshop sorted out so I can use it. I am pretty much there with it now but still have things I want to do to make the workshop better. I have done a little on the rod but not much. I dropped the gearbox (trans) off a trolly jack while trying to set up my crossmember and I broke the case. I hope to be back on it soon nd make some real progress.
    David
  21. 64 DODGE 440
    64 DODGE 440
    from so cal
    Most folks break a ****** with a missed shift or too much horsepower David. You found a different way. Sounds like something I would do. More than likely I would just drop it on my foot. :p
  22. patmanta
    patmanta
    from Woburn, MA
    That ****s. Can you at least still use it for mockup?
  23. Mindover
    Mindover
    from England
    Cheers guys. I was more than a little pissed off. My Mate Glen who built the trans for me was none too pleased either!. I was in on a Saturday morning waiting for a customer and I thought I would use the hour or so to see if I could sort out my crossmember. I was trial fitting it in place and in a hurry so did not chock the trans I just used the trolly jack, eveything shifted and the trans fell., not far but it bloke one of the mounts off and smashed the case. I have got new parts but I have not had the trans rebuilt yet. To make matters worse the customer never turned up.
    Patmanta- I am using an empty block and the old case for mock up now so no more damage I hope.
    David
  24. mika112
    mika112
    After this setback, I hate to see more of your work .
  25. Good to hear you're still at it Dave
  26. mika112
    mika112
    ouppsss !!! sorry .
    After this failure, I Still Love follow your work ;)
    the google translation is bad .... :mad:
    oliver westlund likes this.
  27. daddylama
    daddylama
    just read all 38 pages of this; brilliant! can't wait for more...
  28. Mindover
    Mindover
    from England
    What has happened to all my photos, will they come back?.
    David
  29. sko_ford
    sko_ford
    Im hoping its just a glitch of the new hamb. Might have to ask @Ryan
  30. Mindover
    Mindover
    from England
    Fantastic, my photos are back! I have some new stuff to post soon now I know my thread id not dead.
    Mika, don't worry I knew you did not intend to insult. I know you follow this thread and are using what you learn to build your own T body.
    David
