red lense search
Discussion in 'The Hokey Ass Message Board' started by TBonez, Feb 8, 2014.
  1. TBonez
    TBonez
    Im planning on using these bullet lights for the tail lights on the '29. The guy I bought them from did not know what they came off of so got them for cheap. Searching the internet i found out that they came off a 1940's Dodge Power Wagon. I found one red lense a year ago that works but have yet to find a mate. Recently at Turlock after scouring each booth I ran into an old Willy's guy that said the lense is off of an older Willy's truck and they are hard as hell to get. He said that no cast markings inside are common with this lense. Given the fact that these are hard to find does anyone have a suggestion of a gl*** lense to use. Seen plenty of plastic **** that may work but dont want that. The lense is 2 11/16" in diamiter and about 1 1/8" tall. A domed lense would be good but not necessary. Planning to put the lights about 8" to 12" below the belt line and back so the lense is is even with the rear panel.
  2. Hotrodmyk
    Hotrodmyk
    You might try motorcycle swap meets too. I had a friend tell me that Willys, Indian and some others use the same gl*** lens.
  3. Jalopy Joker
    Jalopy Joker
  4. D.Conrad
    D.Conrad
    When I restored the Johnnie Zaro '40 Merc I used the clear lens and put a round piece of red plexigl*** behind it and it worked fine.
  5. 5window
    5window
    try the website:taillightking.com
  6. TBonez
    TBonez
    thanx for all the help guys. Seen some old harley lights that may work, just waitin to get the dimensions
  7. TBonez
    TBonez
    Thanx.......dont know why I never thought of that
  8. 40FordGuy
    40FordGuy
    Look up some of the older "SignalStat" (brand name) lenses; Those look a lot like some marker light lenses.
    4TTRUK
  9. mr.chevrolet
    mr.chevrolet
    hey, i'll buy those lights if you don't use em.
  10. TBonez
    TBonez
    sorry but they are just right for the build I have in mind.
  11. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    Adlake railroad lantern lenses are 2 3/4” They look real close. You could cut down a signal lens but it would be flat.
  12. 31Dodger
    31Dodger
  13. I just went and checked the 1941 Plymouth lens I have, they are 2 & 5/16th diameter, otherwise look identical, same outside shape and internal ridges......dunno if this helps.....regards, andyd
  14. tjet
    tjet
    That's where I found some gl*** lenses for my 60's Signal-Stat truck lights
  15. Hotrodmyk
    Hotrodmyk
  16. kleinbike
    kleinbike
    from Nor Cal
