...magneto friendly tachometer...
Discussion in 'The Hokey Ass Message Board' started by BERNIES WELDING, Feb 11, 2014.
  1. BERNIES WELDING
    BERNIES WELDING
    I am looking for a tachometer that is compatible to a mid 60's Mallory dual point magneto. everything I have checked on is for todays ignition systems. this is what I am using.
    there used to be units that would be compatible but what is out there?
  2. squirrel
  3. yellow dog
    yellow dog
    from san diego
    Do a bit of research on Zener diode tachs. I had one on a Joe Hunt in the 60's
  4. Midget25
    Midget25
    I used an Auto Meter Signal Converter in my Anglia. Summit P/N ATM - 9118 works fine and I didn't use an Auto Meter tach.
  5. or a 8132 tach adaptor ...can use it on vertex-mallory -hunt..etc.
    [FONT=Verdana, Arial, Helvetica, sans-serif]TACH CONVETER[/FONT]
    [FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif][FONT=Verdana, Arial, Helvetica, sans-serif] [/FONT][/FONT][/FONT][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif][/FONT][FONT=Verdana, Arial, Helvetica, sans-serif]The output signal that is used to trigger magnetos is different than a conventional electronic ignition. This compact device converts the Pro Mag’s coil signal into a 12 volt square wave signal so common tachometers designed for electronic ignitions can be used with the Pro Mag. The Converter is less than three inches in length and its circuits are encased in epoxy for water and vibration resistance.[/FONT]
  6. BERNIES WELDING
    BERNIES WELDING
    who makes this converter? and who sells it, or can I buy manufacturer direct.
  7. yellow dog
    yellow dog
    from san diego
    MSD...........check their tech line
    Toll Free MSD Tech Line: 888-673-7859
    MSD Tech Line: 915-855-7123
  8. BERNIES WELDING
    BERNIES WELDING
    thanks for the help
  9. tjet
    tjet
  10. squirrel
    exactly!
  11. Yep if you do not have a tach drive magneto this is your basic option.
  12. BERNIES WELDING
    BERNIES WELDING
    i ordered a MSD tach adapter #8132 today directly from them.
    thanks for the help everyone.
  13. c322348
    c322348
    Stack makes some tachometers that are old-school magneto friendly. Some of them even look vintage.
