Projects 55 fargo
Discussion in 'The Hokey Ass Message Board' started by crazycooter, Feb 11, 2014.
  1. crazycooter
    crazycooter
    New to the HAMB, picked up 55 from closing wrecking yard, going to make a hotrod out of it just starting project looking for insight into which front end to put in it decided to put 62 pontiac front clip it is the closest to the frame I could find. started looking for front fenders finding out they are harder to find than I thought
      487.3 KB
      452.7 KB
      408.5 KB
      332.8 KB
      266.7 KB
      440.5 KB
      481.2 KB
  2. stevethepreacher
    stevethepreacher
    Welcome to the HAMB. There are a lot of our trucks on here. You will also find a lot of help with your build. Good luck though finding fenders and other parts as they can be scarce.
    Steve-
  3. 73RR
    73RR
    You might find better front clips for the truck than the "Wide-Track" Poncho. Put your tape measure to work on the track not just the frame rails. This might be helpful.. http://cl***iccardatabase.com/index.php
    There are a couple of Dodge truck project threads, use the search ****on.
    There are also several other forums dealing with early Dodge trucks if you look around.
    Check the threads dealing with the Ford F-1 and F-100 as there is considerable swapping going on with them. The Ford truck forum 'FTE'
    is littered with info.
    Oh yeah, post an intro before someone beats on ya.
  4. Boy, bet you will be the only Fargo owner on this board! Any old parts you don't use, try to sell. I would think they are hard to find.
