*#* OK,here is the I love my banger Feb 2014 Banger meet *#*
Discussion in 'The Hokey Ass Message Board' started by Crazydaddyo, Feb 2, 2014.
  1. Ha I'm not sure. Tilley, Tilly, Tillotson? I'm fighting a rust issue in my tank so I've been pulling mine apart about every 600 miles or so to clean out super fine debris that gets through my filters. I keep a gasket set in stock but have I have reused the old ones twice. Just be SUPER gentle with it, you can warp them real easy if you over tighten stuff.
    I can't speak on Zeniths as I've never had my hands on one
  2. Hey, you forgot the picture! :)
  3. gwhite
    gwhite
    SUPER MODERATOR
    Definitely needs a 3/8" reach plug (remember I was having a devil of a time finding any references to 7/16" and 1/2" reach 14mm plugs in my old Champion catalog? - makes sense now!)
    Here's what you need to aim for (sorry for the poor quality photo);
  4. Crazydaddyo
    Crazydaddyo
    Here is a link to a web page that you can plug in the details of the plug you are looking for and it will tell you what plugs are available.
    http://www.sparkplugs.com/Search.aspx?ptn=Spark+Plug
    If you plug in : 14mm thread , gasket seat, & 7/16 reach there are 18 plugs listed by 4 manufacturers.
  5. gwhite
    gwhite
    SUPER MODERATOR
    Sweet, that's a great reference...Hitchiker had asked last month about vintage plugs - I was going through a 1940-ish Champion catalog and only saw one or two 7/16 & 1/2" reach plugs listed in 14mm - they were almost all "J" series (3/8" reach). Looks like there's tons more choices today!
  6. wow Feb already, wish this damn Ice Age would stop so I can get out in the roadster! Im In!
  7. 1931fordtruck
    1931fordtruck
    I second that, but I dont have a roadster. I have a coupe and truck. Im hoping to have the coupe on the road shortly after the Weather breaks.
  8. brett4christ
    brett4christ
    Ok guys, please tell me what this is....
  9. Carter
    Carter
    It is an oil line...:D
  10. RussTee
    RussTee
    often there is a byp*** filter in that line takes oil to the timeing gears makes them run quieter
  11. brett4christ
    brett4christ
    Duh! :)
    I was wondering if this was a part of a pressurized system.....
  12. Ok guys, question....
    I'm running a Don Zigg Vertex Mag on my banger, even though the grub screw and nut holds the unit tight...it rocks back and forwards slightly as if the clearances in the dizzy mount is slightly too large.
    I've been thinking this may be the reason for my odd timing issues..
    So the question is how tight is your dizzy and does it have some front to back movement?
  13. Bluto
    Bluto
    make a bushing and see if you timing problem is cured
    The ink is still drying!!!
  15. Ok next question. Just about to swap on 2x new Stromberg 97 and have a jetting and Power Valve question.
    It's a B block, Denver Miller OHV conversion, balanced, counter weighted, Brierly cam, vertex mag.
    Running in an A roadster.
    Car will be run between 5000-8000 feet, what jet and PV combo would you guys suggest?
    Thanks
  16. Crazydaddyo
    Crazydaddyo
    Can't wait. Back to the 1/4 mile.
  17. I understand that Fontana raceway will be having an Open House this next weekend for the drag strip.
    Not sure what days, I am sure that it is posted on the Fontana web site.
    J
  18. 29 Speedster
    29 Speedster
    from Colorado
    The Flat Tail Sprint Car has a Vintage McDowell OHV, the Victoria has a Serr-Miller, and building a Coupe with a McDowell Replica. The Speedster has a Vintage Thomas Flathead.
    Bob
  19. hotrodA
    hotrodA
    ALEXANDER for me
  20. RussTee
    RussTee
    keep them coming guys
  21. BCCHOPIT
    BCCHOPIT
    No OHV for me.
    I need to do a 100 MPH with a flat head 1st then I will step up to a OHV.
  22. Crazydaddyo
    Crazydaddyo
    Cast iron 2 port Riley, cast iron Rutherford, SOHC Hal, Eubanks, Frick Ardun, Olds 455.
  23. RussTee
    RussTee
    didnt know you had that many crazy it would be nice to see pictures and hear how they run all are interesting
  24. 2 port Riley, 4 port riley, Cragar.
  25. 25mercury
    25mercury
    From the days of the "X cl***" 4 banger dragsters. McDowell head with Nichols overhead cam attachment, B block with 4" destroked crank and Pontiac straight 8 rods. I got it with the McDowell head but it also ran a Cragar head.
  26. Crazydaddyo
    Crazydaddyo
    That is a great engine!!!!!! Is the cam drive taken off of the front of the crank?
    Does the vertical drive shaft run at crank speed with a bevel gear drive?
    Does the can operate the valves directly or are there rocker arms?
    Any more pictures? Especially with out the cam cover.
    Thanks for posting that picture.
  27. RussTee
    RussTee
    this is why I put up this post to see the variety of heads and how they are modifiedthanks 25 mercury
  28. racer32
    racer32
  29. 25mercury
    25mercury
    CDO, that photo is from 1978 when I drug it home from Doc Prudens garage. I took some pics today but the engine is in storage and its hard to get good photos. The vertical shaft runs at crank speed and is driven off the front of the crank by bevel gears. It runs a cup system. At one point it ran in the Merry Men club dragster out of Long Beach (with a Cragar head). If anyone knows any history of this engine please share it with us. Mike
  30. noboD
    noboD
    Mike, have you ever had it running?
