Projects 29 A coupe build
Discussion in 'The Hokey Ass Message Board' started by Wildbill29tudor, Sep 15, 2013.
  1. Wildbill29tudor
    Wildbill29tudor
    Thanks, I plan on running a disc brake set up. I want to make at as traditional looking as possible while still keeping at as safe for the street as I can.
  2. There is nothing unsafe about drums. F-100 drums are a bolt on deal for 46-48 spindals you just need to change out one of the bearings. They are self energizing so you don't have to adjust them like early juice brakes. They can be found easily and are fairly cheap. Just a thought.
  3. Wildbill29tudor
    Wildbill29tudor
    I just like the idea of disc for the fact that I am running a fully dressed big block and the fact that I plan on driving it a lot
  4. Wildbill29tudor
    Wildbill29tudor
    I couldnt resist climbing on the table and sitting in it
  5. ALEISTER
    ALEISTER
  6. Wildbill29tudor
    Wildbill29tudor
    Ordering spring, shackles, perches, kingpins, brake kit, and the u bolt kit from speedway. Any advice?
  7. badshifter
    badshifter
    Buy and use old stuff from the HAMB cl***ifieds.
  8. Wildbill29tudor
    Wildbill29tudor
    So I shouldn't buy new suspension components? I would think that would be something I'd want to buy new
  9. Wildbill29tudor
    Wildbill29tudor
    Yay!
  10. Olderchild
    Olderchild
    from Ohio
    Is that a wrench under your truck:eek:
  11. Rehpotsirhcj
    Rehpotsirhcj
    off to the blaster?
  12. Wildbill29tudor
    Wildbill29tudor
    I wish I still have a little work to do before the blaster comes in to the picture
  13. Wildbill29tudor
    Wildbill29tudor
    Built an xbrace for my frame today just have to cut the ends to fit and weld it in. Will be mounting motor and trans in a couple weeks and channeling the body around it all
  14. Wildbill29tudor
    Wildbill29tudor
    Have to change out the bowtie baby moons for smooth ones but you get the idea
  15. Wildbill29tudor
    Wildbill29tudor
  16. Wildbill29tudor
    Wildbill29tudor
    Finished x-brace
  17. mad mikey
    mad mikey
  18. Is the Chevelle rear stock width? 53 1/4 bp to bp for 64-67 and 54 1/4 bp to bp for 68-72......I have wondered about a stock width Chevelle rear in a Model A frame...
  19. Wildbill29tudor
    Wildbill29tudor
    Thanks, do you have a thread with pics of your car?
  20. Wildbill29tudor
    Wildbill29tudor
    It's a 66 super sport 12 bolt. It seems with my car channeled it will allow the tires to clear the quarters well.
  21. that would make it 53 1/4. how it look with body on it with that rear? thanks for the info
  22. Wildbill29tudor
    Wildbill29tudor
    All depends on wheel back spacing really
  23. yeah...what is a stock model a rear backing plate to backing plate? any idea
  24. Wildbill29tudor
    Wildbill29tudor
    It's narrow, like 48" maybe?
  25. Wildbill29tudor
    Wildbill29tudor
  26. Wildbill29tudor
    Wildbill29tudor
    Trying to get my frame done this week so my buddy and I can work on getting the motor and trans in it, looking for a 32 or a 32-34 pick up grille shell.
  27. Wildbill29tudor
    Wildbill29tudor
    Got x brace in just have to tie it together
  28. Wildbill29tudor
    Wildbill29tudor
    Ordered all my front suspension parts, working on getting my motor mounts, radiator and shell and it's ***embly time :)
  29. Wildbill29tudor
    Wildbill29tudor
  30. Wildbill29tudor
    Wildbill29tudor
