Bell housing identification
Discussion in 'The Hokey Ass Message Board' started by zoegrant, Feb 12, 2014.
  1. zoegrant
    zoegrant
    from CT
    Hi....I have a bell housing that I am wondering if anyone could identify.. The casing is stamped "AJ 6394 C"...What does it belong on ?Thanks,John in CT
  2. brad chevy
    brad chevy
    6394c is a Ford bellhousing but are you sure about the AJ numbers.
  3. zoegrant
    zoegrant
    from CT
    Brad....what makes you think it is a Ford number....all my books show the Ford bell-housings to be #6392 not #6394...I just double checked and it is ...AJ 6394 C...........John in CT
  4. zoegrant
    zoegrant
    from CT
    Brad...you are correct...it is a Ford # but what is it off of ?
  5. Ole don
    Ole don
    If you have the bottom, the starter cup, and the clutch arm, you have a nice part.
  6. USA Tires Sign Joe
    USA Tires Sign Joe
    from Western NJ
    Agreed, this Ford stuff is not easy to find!
  7. zoegrant
    zoegrant
    from CT
    I checked tonight to see what I had and I do have the starter cup,bottom pan,clutch arm,flywheel and pressure plate,clutch plate,throwout bearing,and bearing retainer and a 3 speed with overdrive tranny with a govenor and solenoid ...bought it all at one time a few years back thinking someday I might use it....haven`t yet...John in CT
