32 sedan roof insert question.
Discussion in 'The Hokey Ass Message Board' started by rusty rocket, Feb 12, 2014.
  1. rusty rocket
    rusty rocket
    I did a search and found a bunch of ribbed insert ideas but I want to fill my roof to seal the car up and then put the original tack strip and roof material on. Any body have any donor car ideas that they have used.
  2. Just Gary
    Just Gary
    That's exactly what I did on my '28, although I haven't yet installed the vinyl. I used an '86 Toyota minivan roof.
    Here's the picture-heavy thread:
    http://www.jalopyjournal.com/forum/showthread.php?t=636247
  3. rusty rocket
    rusty rocket
    Thanks just gary. I think i know where one of those vans are. have to go see if its still there.
  4. Pewsplace
    Pewsplace
    Walden Speed Shop has a perfect filler.
  5. rusty rocket
    rusty rocket
    I dont have the fundage to go that route. i figured that I can find a donor car and if the contours arent quite right the pad under the top material can be shaped.
  6. green53ford
    green53ford
    from Wisconsin
    I used one from a mid 70s ford full sized stationwagon. It fit like it was made for it.
  7. Pewsplace
    Pewsplace
    Look at the Eastwood Barakat build thread on here. I think they tell what roof they used on their budget build. It looks perfect when you see the car.
  8. 27 tallt
    27 tallt
    :p One of my friends used the roof off an '85 Dodge Caravan (magic wagon), but reversed it when fitting (front to back). Turned out really nice. Hope this helps
  9. woodiewagon46
    woodiewagon46
    from New York
    Rusty, if you can get a copy of the July 2013 issue of Hot Rod Deluxe magazine, Roy Fjastad of West Coast Street Rods has a step by step photo layout of the job. Walden, as already stated has the insert.
  10. redo32
    redo32
  11. jackandeuces
    jackandeuces
    I just filled a deuce sedan roof with a roof of a early bronco...
  12. krusty40
    krusty40
  13. 32 Spitfire
    32 Spitfire
  14. rusty rocket
    rusty rocket
    Thanks for all the input guys! I found a toyota minivan skin that just gary used in a model a. I made a template from the 32 and the toyota is a damn close match. hopefully the salvage yard doesnt want an arm and a leg for it.
  15. scruff
    scruff
    Early 60's ford station wagon roof skins were often used for this.
  16. Tsquared
    Tsquared
    from Pratt, Ks.
    as were the `57-8-9 ford sw.
  17. rusty rocket
    rusty rocket
    I cant bring my self to cutting up a mid fiftys wagon unless it was totaly clapped out. Minivan or big 4 door sedan on the other hand, give me a cutoff saw. thanks for all the input guys.
