y-blocks
Discussion in 'The Hokey Ass Message Board' started by TP, Feb 15, 2014.
  1. TP
    TP
    from conroe tx
    I have the oppertunity to buy a 54000 miile 292 out of a very nice 64 pickup. It is a good running 2 barrell motor with a 3 spd transmission.I am thinking that I want to run the 3 spd with a floor shifter. Are they available? Can I change the bell housing as some has said and run a 4 spd? or is there an option for a c-4 ******[bad knees]? What's my options? I haven't had a y-block since sophmore year of highschool in a 58 ford and it ate transmissions[3 spds]. Thanks TP
  2. luke13
    luke13
    try a 65 mustang 3 speed toploader, they bolt right up and hve better ratios and syncro 1st.
  3. wldtrout
    wldtrout
    from montana
    Flat-O makes a C4 conversion
  4. TP
    TP
    from conroe tx
    Luke13-Thanks for the information.
    wldtrout- is flat-o the name of a company?
    Thanks guys I'll start looking.
  5. ffr1222k
    ffr1222k
    I know what you mean about those transmissions. I had a 56 Ford Vic in High School. I used up 9 of those transmissions.
  6. Ole don
    Ole don
    There is an adapter to put a late model four speed or a five speed on a pickup or p***enger bell housing, and a fellow who advertises in the Y Block Magazine who puts an AOD on a Y block.
  7. Early T-10 or Top loader four speed will bolt up. Charlie Burns ran a T-10 out of a Galaxie in the "Yellow Brick" for a while but the jump between third and fourth was too big, the Top loader got him the E/PP record.
  8. khead47
    khead47
    ffr1222k- you beat me! I went through 6 3 spds in my 56 wwhen I was a kid. And Flat o Refers to Flat-O-Matic Co.
  9. sunbeam
    sunbeam
    Ford used 2 different 3 speeds behind y blocks.in these years one with a side plate and one with a top plate The top loader was stronger.
  10. Cooon
    Cooon
    I found this on a website recently, not sure with whats involved.
    "Slight modification of a 3-speed column shift bellhousing allows for the use of a much more modern Tremec T-5 overdrive 5-speed with the stock clutch ***embly"
    Would be awesome to keep the column change and have a 5 speed on the column.
  11. PackardV8
    PackardV8
    I've got a '62-65 Borg-Warner Ford T10 4-speed which needs a good home. PM me if you'd like to go that way.
    jack vines
  12. zoegrant
    zoegrant
    from CT
    A T85 3 speed is a tuff heavy duty ****** and they also come with a heavy duty R11 overdrive if desired.....J
  13. Wilcap has a few Y block adapters and Bendtsen offers a Y to AOD adapter kit.
  14. finn
    finn
    The 64 3 speed should be the same basic fully synchronized toploader (3.03)transmission as the Mustang, as far as I remember. The trans came out in 63 in the p*** car, and was used in many GM performance cars as the base transmission in the mid-late 60's (GTO, etc).
    It is a totally different trans from the old non synchro first gear trans used in the 50's and early 60's, and shares the basic architecture similar to the top loader 4 speed.
  15. dana barlow
    dana barlow
    from Miami Fla.
    Be honist with your self,a teenager will kill any ****** :eek:,no matter what it was. Old Ford 3 speed was fairly good old gal,but in a full size car,dumping the clutch on it was a lot of load,yet in a cut down hotrod it could smoke hell out of the tire very well.
  16. gimpyshotrods
    gimpyshotrods
    Wilcap has an adapter to put any GM automatic on it.
  17. TP
    TP
    from conroe tx
    How much are the Wilcap adapters for GM ******?
  18. gimpyshotrods
    gimpyshotrods
  19. 56 ford custom
    56 ford custom
    from Socal
    Both my 56 sedan an 60 f100 have factory fordo's and work great. In my hot rod I will be running a stout 292/T-10
