low radiator - in front of axle ?
Discussion in 'The Hokey Ass Message Board' started by Fenders, Feb 10, 2014.
  1. bgbdlinc
    bgbdlinc
    ...a very cool (haha) solution. From your pic, I can't understand the shape of the lower tank with the outlet above the crossmember, if the bottom of the tank is 6" below the frame. Is the core shortened on the one side to allow the outlet to be located higher on the rad? Or is there some kind of metal/magic voodoo going on? My Flattie needs something like this....thx
  2. Hdonlybob
    Hdonlybob
    Good post...
    I am doing the same thing and glad to see some help here..
    At this stage I just have the radiator mocked up in place..
  3. It's metal magic voodoo !
    If you look close you can see the shroud is cut around the lower hose outlet. There is a fabricated rectangle tube that has the hose bib one one end and the other goes to bottom tank. The shroud then makes it all flush.
    The shape of the bottom tank follows the shape of the 34 truck grille.
    And still has 6" ground clearance.
  4. bgbdlinc
    bgbdlinc
    ....damn fine solution and I'll bet a ton of brain cells were sacrificed during the process...
    thanks for the info...
