1950 Olds Rocket 88 V8 324
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by dax181, Feb 16, 2014.
  1. dax181
    dax181
    Hi I am an Aussie that has just imported into Australia, a 1950 Olds Rocket 88 V8 324 into Australia but I am having trouble :mad: matching and finding the Ch***is and Engine no's as I need them for rego. It has a door jam tag but this doesn't match the DMV id no and both don't match the DMV transfer no. If anyone no's where they are located please let me no but also been told the tag is also the ch***is no and could the DMV id no be for the other engine 303. Cheers Dax
  2. 55olds88
    55olds88
    tag is probably on the firewall with the body/ch***is info if anything like the 55 (from memory mine is left hand side and pretty east to see), engine # will be on the left hand side of the block at the front, if you look down between the first and middle exhaust port at the block you should see it there (again from memory) otherwise have a search on here.
  3. dax181
    dax181
    Mine has the id tag in the door jam and no engine no on the block between 1 and 3 as I think it could have been a crate engine as its a 324 not the 303 that should be in it. Do you no where I will find the ch***ic no or is the tag the ch***is no too
  4. 55olds88
    55olds88
    hmm you got me beat then, not too sure on the ch***is # location but I'm sure they will have stamped one, so you are saying with the engine you can see the flat area where the # should be stamped but there is nothing there ? (its kinda difficult to see at the best of times).
  5. dax181
    dax181
    There is deffinatly nothing on the pad between 1-3 cylinders and It will be so hard to stamp one on there as you cant get the swing of the hammer to hit it hard enough to leave an imprint, it would have to about 450mm long to be able to hit it with force and still no luck finding where ch***is no is even after contacting the DMV and CHP in the USA
  6. 60rftc
    60rftc
    from LBC
