Use of Misc. left over parts sitting around
Discussion in 'The Hokey Ass Message Board' started by lrs30, Feb 19, 2014.
  1. lrs30
    lrs30
    from Kentucky
    Ok so thru the years I have collected many left over parts, so my question is has anybody used these with any success, or are they a bucket of ****?
    1. I have several rear Model A bones. Has anybody has luck welding up the seam
    And using this for anything else other than on a stock model A?
    2. F-1 spindles, has anybody cut off the bolt on steering arm mount and used
    Say speedway bolt on lower steering arms for a cross steer set up?
    3. Front model A bones, basically same question as number one?
    4. Model A spindles junk or can they be modified to be used to mount later
    Model juice brakes to, if so what years will work? F-1 brakes?
    5. Model A axles, even though they are not dropped, are the king pin bosses the
    Same diameter as later years? If so what years fit.
    So this is just things I have in the pile that I have questions about, all though it may be common knowledge to some, I figured it may help me and others out also...
  2. Carter
    Carter
    #1. I'd sell them to someone to use on a stock A rear.
    #2. Don't know, never used em.
    #3. A front wishbones are fine for use on an A or split and used on a hot rod.
    #4. Same as #1, though guys sometimes use them with juice brakes.
    #5. All of the Ford p***enger car and light truck(pickup)axles 28-48 have same kingpin diameter and perch bolt diameter. A axles are good for dropping because of the longer distance between perch and kingpin.
  3. vwdave30
    vwdave30
    #2 me and my brother have used the f1 spindles on 3 different front axles they work good just cut off the ugly and bolt on some speedway arms
  4. vwdave30
    vwdave30
    #5 got a model a front axle on my coupe
  5. 2. F1 spindles/stubs on a p***enger car I beam ( model A etc ) the camber is wrong due to the F1 spindle have a different kingpin inclination .
  6. HammerDown
    HammerDown
    Negative ghostrider. F-1 has the same kingpin inclination as early Ford. F-100 however, does not. The F-1's are fine. As someone else said just shave off the ugly...
  7. lrs30
    lrs30
    from Kentucky
    So the f-1's won't work on am A or p***enger car I beam due to the inclination correct! I have not tried fitting it
  8. 41hemi
    41hemi
    I've used F1 spindles on many 28-48 Ford P***enger axles. No problem.
  9. lrs30
    lrs30
    from Kentucky
    Ok I thought they looked like a round back spindle short of the wart on them
  10. Ahaa! you are likely correct . I had a customers project that had a Model A axle with what he was told were F1 and the camber was shocking , as you point out they were likely F100. I shall consider myself on a warning and stand quietly facing the corner of the room for 5 minutes ! :eek:
  11. lrs30
    lrs30
    from Kentucky
    What about rear model A bones, if I remember correct that are thinner material are they not?
  12. Hot Rod Nut
    Hot Rod Nut
    Yes ,they are thinner, but I have used then on 2 drivers I built with no trouble.
    Keep them.
  13. lrs30
    lrs30
    from Kentucky
    Come on keep them? I never throw anything away hahahah. Just kidding yhea I will keep them just curious about using them with success, and it sounds like it's been done.
  14. Ford Mike
    Ford Mike
    I made a hybrid unsplit wishbone for the front of my av8 out of a stock model A wishbone and a 34 ford truck. I will also most likely be making the rear radius rods for my 36 ford rear in the av8 out of model A rear bones. In my eyes no old ford parts are junk, you just need to get creative.
  15. ydopen
    ydopen
    I keep old model A parts. They are are always good for something. I used a model A front axle to mock up my roadster and then used a 34 dropped.They for good for reference even if you don't use them.
    John
  16. lrs30
    lrs30
    from Kentucky
    I think most of this stuff is gonna be used on a fibergl*** T bucket I just nabbed off Craigslist. It will be sorta a mish-mash of parts, not traditional HAMB fodder, but something I hope to get my boy involved with.. Of course he is 15 and more Interested in the cute blonde that sits in front of him in home room, than making sparks in the garage, but as soon as he figures out that chicks dig guys with cool cars he may come around... Unless those chicks dig guys with Honda accords and neons, and in that case he better find a better cl*** of honey! Anybody have any pics of parts mentioned above that they have put into use? Just for giggles?
  17. pasadenahotrod
    pasadenahotrod
    from Texas
    My son was driving my friend's T track car around Garner State Park one summer when we were there, I had written "Garner Girls Ride Free." across the top of the windshield with a grease pencil, He stopped at the camp store and a big harsh-voiced, but nice, woman about 40 or so strode up to him and said "I'm a Garner Girl, can I ride with you?" He was about 17 at the time and just started the car and took off. He just didn't know how to handle that one. The car was a hit with all the Garner Girls though.
  18. fab32
    fab32
    Usually you only get one shot at a Mrs. Robinson growing up. If he had taken her for a ride it probably would have ruined him for life. I p***ed on mine also and later I found out she gave the best "instruction" you could ever hope for from any teacher.:eek::cool::D:D:D
    Frank
  19. lrs30
    lrs30
    from Kentucky
    ^^^^^^^^^ speaking of leftover parts! I took the shot at one at 17 (45 now)she was 35 and supposedly going thru a divorce (we worked at the same chili parlor) and be young and dumb and full of, well you know the rest I fell for it! Drove her home she offered up a night cap, one thing led to another, and as I was getting dressed her freaky old man walked out of the closet! ******* was watching us the whole time, it was a set up..lol I was invited back but never went:eek: oh well I sure don't regret it she put on a stellar performance:D.... Anyway anybody have any pics of how they used any of the parts mentioned above? Not the Mrs. Robinson pics,although you can send them to me directly hahahahahahaah we need to keep it PG on here...lol
  20. A bird in the hand is worth.....................just saying. :D
