Painting white wall tires
Discussion in 'The Hokey Ass Message Board' started by Kingrat, Feb 18, 2014.
  1. Kingrat
    Kingrat
    Does anyone know anything about painting white walls on tires? What paint to use and if it lasts?
  2. Back in the '50's they sold paint just for that purpose. That's the way we kids could afford whitewalls.
  3. Kingrat
    Kingrat
    I need to find that paint. Did it yellow or rub off?
  4. mastergun1980
    mastergun1980
    from Alva OK
    I have tried several things ( they don't make 22.5 white wall truck tires ) -
    1. Paint will not stick to new tires I don't care what you try it will not work. They need to be a couple years old.
    2. Clean your tire with lacquer thinner.
    3. sand off the letters
    4. whitewall paint works ok... but so does krylon fusion
    If thay make the size you want in a whitewall BUY IT
    mrspeedyt likes this.
  5. Kingrat
    Kingrat
    Awesome thanks for the tips guys
  6. HOTRODPRIMER
    HOTRODPRIMER
    Go to you local paint store and ask them if they have a 100% acrylic house paint..regular exterior latex house paint will not last a week.
    This is how us poor kids did it back in the 60's,,we also used the 100% acrylic black paint to cover white letter tires.
    The 100% acrylic house paint will expand and contract to a certain extent with movement of the tire.
    Like any white wall even the acrylic will yellow over time,,just add a fresh coat of paint.. HRP
  7. Kingrat
    Kingrat
    I will try that. Thank you
  8. 49john
    49john
    I Googled "White Wall Paint". Couple
    places on EBay came up.
  9. Kingrat
    Kingrat
    Ok thank you
  10. joe (pa)
    joe (pa)
    from Central PA
    I used elastomeric white roof paint. I think it's called duck coat, or something close to that. Went on easy, no cracking, but my only disappointment was the yellowing. I used New tires, so that may be why, but it didn't matter much to me because my Plymouth has patina, (bad paint job,) and I needed tires anyway. So they fit the car visually pretty good
  11. Camel toe kid
    Camel toe kid
    I did house paint on a chopper of mine n when the paint was tacky just about dry went down a gravel road n looked jus like an aged whitewall!
  12. oldrelics
    oldrelics
    from Calgary
    I used Krylon Fuzion on some minibike tires, it stayed on okay but yellowed in a year.
  13. oldpl8s
    oldpl8s
    Try one at a time. I painted all 4 with a rattle can and they paint cracked on the first drive,then I have to s****e it all off.
    metlmunchr likes this.
  14. TeamEvil
    TeamEvil
    If you begin with white lettered tires, you can use a grinder and sander to remove the thin black rubber coating that covers the rest of the side wall and reveal the white beneath. Check YouTube for loads of videos on this trick.
    Touch up with the white roof paint if needed and it might well be the answer for you.
    Luck,
    TC
  15. mashed
    mashed
    from 4077th
    <TABLE cl***=tborder cellSpacing=1 cellPadding=6 width="100%" align=center border=0> <TBODY> <TR> <TD cl***=tcat>[​IMG] [​IMG]Searching Forums and Threads</TD></TR> <TR> <TD cl***=alt1> How do I search for something?
    To quickly find a thread or post of interest anywhere on the bulletin board, click on the 'Search' link in the navigation bar at the top of most forum pages. Then, type in the keyword or phrase you wish to search for, and select either 'Show Threads' or 'Show Posts' to view the results. By selecting posts, you will be shown only the actual post in which the search word appears.
    For more control over the search, select 'Advanced Search' from the drop-down box. The advanced search page allows you to restrict your search to individual forums, find posts or threads by user, or return results based on tags (?). There are also options to find posts from a certain date, or threads with a certain number of replies.
    </TD></TR></TBODY></TABLE>
  16. Kingrat
    Kingrat
    Yeah we tried grinding the sidewall but the whitewall is uneven.
  17. This is the answer. start looking around your local area for a tire shaver guy. You will find someone that still provides the service, its a mounted grinder that cuts a clean circle around the wall of the tire as its rotated. I've even seen them at car shows do them while they were still mounted on the car
  18. TeamEvil
    TeamEvil
  19. CraneOpTrev
    CraneOpTrev
    Good luck finding one nowadays, but a ballsy machinist could trim an aired up tire on a lathe making it a perfect whitewall.
  20. jnaki
    jnaki
    Hey KR,
    Back in the 1957-63 era, we did use paint as a means to get whitewall tires. They looked good for a short time and when you accidentally rubbed against the curb in parking, that was it...You had to start all over. Over time, they did not look good, so we tried some add on white wall inserts. It installs on the rim when you deflate the tire and then when inflated, it can not come off while driving. If you happen to rub on the curb, sometimes they wrinkled and you may have to get some new ones.
    Well, jump up 50+ years and Moon Equipment has some "newish" versions of these add on whitewall tires.
    https://www.mooneyesusa.com/Port-O-Walls-Wide-White-p/ww12.htm
    No painting, no mess, no fuss... check it out.
    Jnaki
    spurgeonforge likes this.
  21. LOL I used a magic marker, until I found out about indelible laundry markers. :D
    I used white acrylic house paint on a kids Caddy to make wide whites when I was in high school. It worked real well.
    These days it seems like you could use the paint with the flex stuff in it like they use on plastic/rubber bumper covers.
  22. Graystoke
    Graystoke
    Has anybody tried Plastidip?
  23. pumpman
    pumpman
    B F Goodrich.JPG They did it way back when too. Guess it didn't work that well back then either.
  24. Toqwik
    Toqwik
    What about that flexseal stuff. If it can stick to everything they claim it should stick to a tire.
  25. Kan Kustom
    Kan Kustom
    I searched this for quite some time awhile back. I am painting the white and blue on a set of 60`s Goodyear Blue Streak slicks. I even went as far up the ladder as I could get at Goodyear and couldn't get the answer. They said they had no clue what paint was used back then and that the new slicks had color done in the molds. The only thing I could get a consistent answer on was Acrylic Latex house paint. I still haven't had the guts to paint my slicks yet.
  26. Kan Kustom
    Kan Kustom
    Nice display.
