Help identifing grille shell..early Chev?
Discussion in 'The Hokey Ass Message Board' started by beverlyhillbilly, Feb 21, 2014.
  1. beverlyhillbilly
    beverlyhillbilly
    Can anyone identify this shell..Early 30's......Chevy..Car?..Truck?
    Thanks all..
  2. bonzo-1
    bonzo-1
    Looks mid 30s chev
  3. Could be off a 30's International?
  4. Master of None
    Master of None
    Looks like a 33-34 Chevy to me.
  5. 50ChevyFrank
    50ChevyFrank
  6. harleycontracter
    harleycontracter
  7. 52lomofo
    52lomofo
  8. Allmotor
    Allmotor
    It"s a 34-35 Chev std or 34 master. The master is bigger than the standard.
  9. 26 T Ford RPU
    26 T Ford RPU
    My pick is Chev 33-34 car and up to 36 truck. JW
  10. primed34
    primed34
    Looks like a '34 Master. Master is narrower and longer than the '34 '35 standard. The '33 does not have a removable trim ring.
  11. bishop327
    bishop327
    from CO
    Not a 35 master. Fill on 35 master is behind shell. No hole in top of shell.
  12. TomH
    TomH
    Yes.
  13. primed34
    primed34
    Just measured my '34 Master. The grill insert area should measure 31 1/2 inches top to bottom. Standard is shorter.
  14. mgtstumpy
    mgtstumpy
    Looks like my 34 Standard. I'll measure insert depth tomorrow as you already have Master dimensions
