Technical TECH WEEK: Cutting curved laminated glass the cheap and easy way.
Discussion in 'Traditional Customs' started by Morgan91, Feb 22, 2014.
  1. Morgan91
    Morgan91
    from Australia
    I recently chopped my 51 chevy and couldnt really find anyone near me that would cut the windshield gl***, all the local gl*** guys said it was a big deal to cut curved gl***.
    I did a little bit of research and some experimenting with a couple different ways and found it to be pretty easy and risk free to cut using a sand blaster...
    All you'll need is a small sand blaster (I used one with a 1/4" nozzle) some good quality masking tape (I like the green scotch brand tape) some paint thinner or alike and some patience.
    Im not very good at explaining things and I forgot to take pictures of the actual cuts I did on my windshield but iv got pictures of a practice cut I did on a spare chevy windscreen I had that worked out well so I will use those and try my best to explain how I did it (pretty straight forward)
    basically all I did was mask a 1/8" line (both sides) in the gl*** where I wanted the cut layering the tape about 3 or 4 times so that it was thick enough to hold up to the sand blaster:
    in this picture I already started blasting but you can see the tape and the paper protecting the rest of the gl***.
    I then slowly blasted away at the line back and forth (trying not to heat up the gl*** to much) until I got down to the laminate in the center then flipped it over and did the same on the other side...
    I found that the laminate was really tough and wouldn't cut very well with the sand blaster so I poured some paint thinner down the cut line and it began to get soft pretty quick, I lit the thinners and the two pieces separated easily..
    I used some 36 grit sand paper to sand the cut line smooth and I was done!
    when I cut down my actual windshield the cut curved around but its exactly the same process, each piece of the windscreen only took me about an hour each to do.
    Sooo yeah..... any questions?
  2. Hnstray
    Hnstray
    from Quincy, IL
    Thanks for posting. Glad to see it works so well.
  3. kippers 34
    kippers 34
    I have used this method before. works great. Slow and messy but but the results were worth it.
  4. 4rod
    4rod
    what about using a gl*** cutting tool, score both sides then BBQ fluid over the score, light it and it will melt through?
  5. fordcragar
    fordcragar
    from Yakima WA.
    In theory it might work, but the results might not be what you are expecting. If it were that easy, more gl*** shops wouldn't hesitate to chop your windshield.
  6. racer_dave
    racer_dave
    4rod- that-s how we used to do it at the gl*** shop I worked at. I like the sandblast idea too though.
  7. gnichols
    gnichols
    from Tampa, FL
    Interesting. Best grit size? Pressure? Gary
  8. kippers 34
    kippers 34
    I went to several gl*** shops that supposedly could cut windshields and none of them seemed the slight bit confident in their ability. At 2 or 3 hundred per windshield I dident feel confident trusting any of them. After a little research I decided that I could sandblast my own and make it on the first try. And I did. I used duct tape instead of masking tape (seemed the most resistant to the blast) with quite fine grit media and low pressure in a small cheapo blaster to slowly cut through. You can cut around corners just as easy as a straight line.
  9. Morgan91
    Morgan91
    from Australia
    I did try that on a test piece but couldn't get it to work....
  10. Morgan91
    Morgan91
    from Australia
    sorry I am unsure of the grit size although it was pretty co****. and just normal shop compressor pressure, about 90 psi....
  11. carlisle1926
    carlisle1926
    From experience, I can tell you make sure you use several layers of duct tape instead of that green tape. It doesn't take a whole lot to cut through that masking tape. Also, ALWAYS cover both sides of the gl*** completely if you are doing it for real. Otherwise, you will have little ricochet pieces of sand making little marks on the gl*** in areas you didn't think was possible. I usually use at least three layers of duct tape around the immediate area that I will be cutting, and then I use cardboard over the rest of the area that I want to protect. Once you get down to the plastic laminate in the middle, a simple box cutter will take care of that. No need for thinners or fuels that can wick their way into the laminate and cause damage.
  12. chrisp
    chrisp
    What media did you use?
    I ask because people talk about sandblasting even when they use gl*** beads, nutshell, aluminum oxide and well sand...
  13. Morgan91
    Morgan91
    from Australia
    just normal sandblasting garnet.
  14. Morgan91
    Morgan91
    from Australia
    thanks for the tip dude! Il use that next time!
  15. GearheadsQCE
    GearheadsQCE
    Alliance Vendor
    My understanding was that the burning of the plastic was to ***ure the seal of the gl*** edges to the center core.
    I don't know if this is true and I have never done it. Just trying to prod an explanation from someone in the know.
  16. flynbrian48
    flynbrian48
    x2 on that. Even the "dust" from blasting will quickly frost the gl***, and you can't polish that off. You won't even notice until the first time you drive into the setting sun. Trust me on that…
    Brian
    QUOTE=carlisle1926;9557037]From experience, I can tell you make sure you use several layers of duct tape instead of that green tape. It doesn't take a whole lot to cut through that masking tape. Also, ALWAYS cover both sides of the gl*** completely if you are doing it for real. Otherwise, you will have little ricochet pieces of sand making little marks on the gl*** in areas you didn't think was possible. I usually use at least three layers of duct tape around the immediate area that I will be cutting, and then I use cardboard over the rest of the area that I want to protect. Once you get down to the plastic laminate in the middle, a simple box cutter will take care of that. No need for thinners or fuels that can wick their way into the laminate and cause damage.[/QUOTE]
  17. 117harv
    117harv
    I have seen some work from a local blaster that has done both rock and wood signs and he says that he used rubber backed tape of some type, where he gets it I dont know. I would think finer grit would work best, and yes cover the whole window as suggested...thanks for he tech.
  18. chopolds
    chopolds
    from howell, nj
    Rubber resist tape works best, at least at the cut line...used in the "tombstone" engraving biz!
  19. MoparFinman
    MoparFinman
    from Okla
    haven't seen it done this way !
  20. summersshow
    summersshow
    from NC
    Cause hes showing another way to do it... Theres more than one way to skin a cat...
  21. chopolds
    chopolds
    from howell, nj
    Curved gl*** doesn't like to be cut with tools made for flat gl***!
  22. bct
    bct
    blasting stencil made by anchor products . also you can use chuncks of old tape measure to cut the laminate. it is thin and flexible
  23. bct
    bct
  24. summersshow
    summersshow
    from NC
  25. bako48
    bako48
    you can use three layers of 7mil duct tape it works great and sticks good.
  26. seb fontana
    seb fontana
    from ct
    After being cut and installed how does the gl*** hold up as far as delamation ?..I've had new gl*** [from two different places] that lasted only a year and it was just flat gl***..
  27. Morgan91
    Morgan91
    from Australia
    Havent had mine in for very long... so I couldn't tell you. Will let you know in a few years....
  28. chopolds
    chopolds
    from howell, nj
    I chopped the windshield in my 55 Olds, back in 1984, and it still looks good, no delamination, but it's stored inside, though it did spend a years out of doors.
  29. jazz1
    jazz1
    Good thread,,don't usually learn something new before my first coffee. How was the fit? I have made curved windshields for boats out of lexan and 2 cuts usually turned into a dozen for a perfect fit
  30. Morgan91
    Morgan91
    from Australia
    Fit was pretty good I made templatea out of plexigl*** first and test fitted them in the rubber which helped a heap the first time I did it I did it ofd mesurments and had to do 4 or 5 cuts before it fit and then I ended up breaking it putting it in cause it was to tight...
