Projects GAZ 12 «ZIM» Custom coupe (Russian build)
Discussion in 'The Hokey Ass Message Board' started by Razer, May 8, 2013.
  1. LeadSledMerc
    LeadSledMerc
    Thanks for the updates...and keep them coming, please!
    Continues to look awesome! :cool:
  2. greazy john
    greazy john
    Very nice work....thanks for sharing.
  3. japala
    japala
    from Finland
    Are those nice wheels russian made? I just find this thread and now i gonna lift my hat to you and your skills
  4. Bumgaz
    Bumgaz
    No, those wheels are american made.
    Thanks for your attention to project. New update'll coming soon.
  5. Lee_Ford
    Lee_Ford
    Looking like it is going to be a nice ride. Good job!
  6. unkledaddy
    unkledaddy
  7. 40ply
    40ply
    Amazing work!!! subscribed.
  8. Flipper
    Flipper
    from Kentucky
    I happen to like the wheels. This is a great project!
  9. AHotRod
    AHotRod
    Incredible Craftsmanship and Design.
    Well done!
  10. Olderchild
    Olderchild
    from Ohio
    I did not save this thread the first time i saw it i will not make that mistake twice very nice work====Jack
  11. nzsimon
    nzsimon
  12. juhap
    juhap
    from Finland
    This is cool.
    How about windscreen and other windows? Do you have local supplier? If not, try Kuttilan Autolasi in Salo, Finland. They do most of the impossible ideas happen... around the world.
    I have to do something to my Chaika project...
  13. Stretchmobile
    Stretchmobile
    from So Cal
    Who needs politicians. We car guys should rule the world. We all speak the same "language" and respect the others skill and talent. Igor deserves the attention. I had no idea craftsmanship of this caliber existed in Russia. Awesome undertaking and kudos for translating into English and posting pictures.
  14. 38Chevy454
    38Chevy454
    Very nice work. Kind of what I think the old coach builders used to do.
  15. Bumgaz
    Bumgaz
    I have no troubles with windows in Moscow. I can offer any windows of any forms here.
    Thanks for your attention to details!
  16. 4444Design
    4444Design
    awesome project
  17. Bumgaz
    Bumgaz
    I'm completely agree with you!
  18. jhexide
    jhexide
    unreal what this guy does with metal
    awesome work,ill be following
  19. lordairgtar
    lordairgtar
    Awesomeness in Moscow.
  20. koolkemp
    koolkemp
    Wow can't believe I missed this build! Great workmanship !
  21. Looks GREAT!! Very well done.
  22. Igor takes metal working to a high level! The workmanship is second to none! Subscribed!
  23. Bumgaz
    Bumgaz
    Well, there's something interesting and new.
    For the manufacture of the rear wings I had to create a master model. Of the many options, I chose the old proven method - creating spatial metal frame using profiles and wire.
    As usual, it all started with the drawings. I draw a horizontal cross-sectional life-size and arched its profile by tube of 15x15 mm. Then I cut the profile obtained grinder to get two completely symmetric details of future products. Likewise I made a pattern of longitudinal and transverse sections of the wing. Then I mounted the parts on the body, in order to avoid inconsistencies. I did it with the help of semi-automatic tack. When the main support lines are ready, I filled in the volume segments of the binding wire section 5 mm in advance giving them proper form.
    Work is not very difficult, but requires accuracy, attention and perseverance. For those who ever wants to use this experience, I advise you to listen to rock ballads, really helps.
    turboroadster likes this.
  24. This is a grate build
    the detail in inner panels
    the metal work
    I will fallow this
    Thank You
  25. lordairgtar
    lordairgtar
    Good craftsmanship on the rear wings.
  26. Zed
    Zed
    from FRANCE
    amazing work ! great lines ! thanks for sharing your skills ! ;)
  27. xpletiv
    xpletiv
    from chiburbs
    Holy ****, awesome work!!!
    Those wings are a piece of art-could hang on a wall!
  28. Bumgaz
    Bumgaz
    Hello again!
    Today I'm going to tell you about windows.
    Doors are very complex spatial arrangement, inner surface does not lie in one plane and has a whirling that is caused by a body structure. The outer surface is so complicated that building it without a hard skeleton is impossible.
    Door design (rigidity, brackets, fasteners and gain) is created from scratch, according to the Nikita's design.
    One of the design features of these doors is hardtop, i.e. absence of the window frame.
    The door with such glazzing is impossible to build without the gl*** itself, and the gl*** can not be made without knowing its geometrical parameters, which in turn is determined by the geometry of the body. In this regard, we decided to create a separate virtual 3D model of the door to the existing parameters, with glazing and internal structures. This model will allow us to get all the parameters of any items cons***uting our design, including very complicated shape gl***.
    Lets take a closer look to gl*** form.
    The fact that the gl*** has not only a vertical bend, like the majority of modern vehicles (in a front view), but also horizontal (in plan view). Thus it turns out that the form of gl*** is spherical, besides it has a whirling due to the shape of the roof, in plan view. It should be noted that a**** of modern cars this decision is quite rare. Examples are cars like the Volkswagen Beetle convertible, model 2012, Bugatti Veyron, and some others.
    Window lifter on the frameless doors should also have a special design. It serves not only as a mechanism lifting / lowering of the gl*** but also a guide to where the gl*** moves along the desired trajectory. With electric window we were lucky: bend and length as well as possible came from the Toyota Supra.
    All 3d-works were made in Solid Works by Felis (It's one of our co-worker).
  29. Stretchmobile
    Stretchmobile
    from So Cal
    Thank you professor Igor. Very clear explanation. Can't wait to see it realized in full scale.
  30. v8juice
    v8juice
