Projects Crazy Mustang II power steering rack Ghost in the car.
Discussion in 'The Hokey Ass Message Board' started by aldixie, Feb 23, 2014.
  1. aldixie
    aldixie
    I have just finished installing a Mustang II front end in my 50 Chevy, everything was a tight fit. Using a T Bird power rack with a GM pump as I have a serpentine belt setup.
    Today is the first time I have put fluid in the pump. No leaks and steering hoses are in the right places. Problem is as soon as I touch the steering wheel the wheel starts oscillating left to right and and right to left extremely fast to the point it sounds like it's going to break the steering column.
    I have ordered the pressure valve for the GM pump to reduce the pressure. Is this the problem?
    Thanks,
    Alex:confused:
  2. Texaswino
    Texaswino
    Sounds like hoses are reversed.
  3. Deuced Up!
    Deuced Up!
    Yep...I did the same thing on my Model A...I put a LEE Sprint Car box in it and got the lines mixed up. When I touched the wheel it just about ripped my hand off whipping left right left right. It was scary!
  4. 32v
    32v
    from v.i.
    yup
  5. gimpyshotrods
    gimpyshotrods
    Yup. Swap the hoses.
  6. 54vicky
    54vicky
    I agree swap the hoses.
  7. metalman
    metalman
    Having the hoses backward is a good way to break a thumb. Guess how I know!
  8. Rocky
    Rocky
    Classified Editor
    I was just sitting here wondering how many guys have gotten hurt after connecting GM PS lines to mustang racks..after all if you connect the male to female lines it looks like that's the way the lines go...not.
    My neighbor put a shiny new mustang rack under his 36 chevy with a 350 motor and stock chevy pump and lines...almost took his hand off when he touched it.
  9. diamond dave
    diamond dave
    yup. happened to a buddy of mine in his 48 ford. hoses were reversed.
  10. aldixie
    aldixie
    I'll check them again tonight. It looked like they would only go on one way. They are a POS to get to with the front end sheet metal back on.
  11. Blue One
    Blue One
    from Alberta
    Don't check them, change them. You have been told what your problem is. ;)
  12. onetrickpony
    onetrickpony
    from Texas
    Yep, like they said, the hoses are reversed. I once did the same thing on a Ford with the external power cylinder. It sacred the **** out of me when I cranked it up to check for leaks.
