brake line clamp spacing
Discussion in 'The Hokey Ass Message Board' started by buford36, Feb 24, 2014.
  1. buford36
    buford36
    from Maine
    I have a friend building a 32 who asked me what the spacing of clamps holding brake lines should be. I said he had to much time on his hands:rolleyes:. He said he thought there was an industry standard for correct spacing. News to me; has anyone heard of such a spec? Thanks, Tom...
  2. chaddilac
    chaddilac
    Moving right along...
  3. Flatheadguy
    Flatheadguy
    More than one inch. Less than ten feet.
    (a serious question?)
  4. Don's Hot Rods
    Don's Hot Rods
    from florida
    Stick shift or automatic ?
    Don
  5. oldolds
    oldolds
    Ok. I will be serious. Today cars are about ever 12". Some even closer. On an older car I would go about every 16" or what looks good. The more the better. The theory is that the vibration will work harden the lines causing them to break. A little bit of info picked up at anti-lock brake cl***es.
  6. cayager
    cayager
    The correct answer is... Who gives a ****!
  7. harleycontracter
    harleycontracter
    I guess How many clamps do you have ?
  8. What ever it takes, and probably won't be even spacing.
    I've seen sections where they are 3-4" apart followed by 16" spacing back to 6
  9. gimpyshotrods
    gimpyshotrods
    No more than 20" apart. Evenly spaced across spans.
  10. Lone Star Mopar
    Lone Star Mopar
    How much wood would a wood chuck ?
  11. river1
    river1
  12. chopped
    chopped
    I tack mine every foot or so.
  13. tmfcracing
    tmfcracing
    from Sweden
    Every 8" is what you have to do if you live in a country with regulations. Even without a rule to follow 8 inch is good. No rattle .
  14. rusty1
    rusty1
    radials or bias plys?
  15. woodiewagon46
    woodiewagon46
    from New York
    Your friend is building a '32 and can't figure out how many line clamps to use? Tell him to just use common sense and add clamps where he feels necessary. It isn't rocket science!
  16. Here in New Zealand the regulations state 12" maximum.
  17. 48FordFanatic
    48FordFanatic
    from Maine
    Go to the NSRA site and check the 23 point NSRA inspection requirements.
  18. tikiwagon13
    tikiwagon13
    here is the formula to use:
    Length of the brake line, divided by the diameter of the line. Take this number and subtract it from the total length of the car, once you have done this weigh the car, take half of the weight of the car and add this to the number you already have. Now check the temperature outside, above zero add it to the final number, below zero, subtract it. Once you have this final number subtract you age from it. If it is less than 12, round up to 12, if it is more than 12 round down to 12.
  19. 55chieftain
    55chieftain
  20. This is how we always do it here.
  21. 54vicky
    54vicky
    you forgot to specify fahrenheit or celcius also windchill should be factored.does wind from east make difference?
  22. ct1932ford
    ct1932ford
    Wait I need to check with the DMV:rolleyes:
  23. I think this is an intelligent question, obviously some here can't manage to crawl out from under their rock and see it this way!
    I've always supported the ends, joints, bends and about every foot between and never had a line crack, break, or leak from lack of support. If you use the aircraft standard of 9" for 3/16 brake lines you won't be wrong.
  24. unkledaddy
    unkledaddy
    What do the instructions say?
