Projects 22 Model T tub
Discussion in 'Traditional Hot Rods' started by Greg Stokes, Feb 15, 2014.
  1. I like your color choice too. Seems right for a banger powered T.
  2. fritzthecat
    fritzthecat
    Great Projekt!
    I will start the same this summer a banger t for the family 1392886922243.jpg
    My wife is trying sitting in it the first time...
  3. Thanks again everyone. Fritzthecat you have a more complete body than what I'm starting with.
  4. Got my wheels ready to mount the tyres. Widened rears.
    Went out in my roadster tonight and couldn't resist this shot.
  5. Was that your roadster at the Nats in Masterton with a grey hood ? JW
  6. No not that car - but I took it to Deuce Days in Masterton 2012
    Roy Brizio driving it
  7. Love this!!!!!!!!
    Keep up the good work
    Tyres and a box of tubes ready to fit
  9. Bolted the T sub frame down on to my Deuce chassis jig. I now have a sturdy platform to work from to square up the body and frame it out.
    Got the rear section sitting on there and will move forward and mount the cowl etc this week.
  10. Tonight's progress - next up square this up and make a spine type frame to hold the body in place to steel frame it out...
  11. Love the truck!,,I'm sure the tub will look great in the same color. HRP
  12. Took my Willys to a local Vintage Harvest Festival and found you a parts car !! JW
  13. Perfect!!!!!!!
  14. Tonight's progress with the jig to frame the body ImageUploadedByH.A.M.B.1393325264.636421.jpg ImageUploadedByH.A.M.B.1393325286.658466.jpg ImageUploadedByH.A.M.B.1393325298.989043.jpg ImageUploadedByH.A.M.B.1393325312.463529.jpg
  15. olskool34
    olskool34
    That looks soooooo familiar. I was basically doing this same thing with mine about 4 months ago except I ditched the middle of the body and turned it into a roadster. There is alot more steel in your body than was in mine. I have never seen steel subrails, even those braces on the back panel are steel. Mine were wood.
  16. sadsack
    sadsack
    im jealous sadsack
  17. need louvers ?
    need louvers ?
    Ya, that's what I was saying earlier! Every "T" I have has had a wood subframe before '26... Interesting.
  18. olskool34
    olskool34
    I asked a few T guys I know and they have never seen them either. They are baffled.
  19. wsdad
    wsdad
    I wonder how a narrowed tub would look. You know how they sometimes take a roadster and narrow it to one seat? I wonder how a tub would look narrowed to two seats - one behind the other. Just thinking out loud. I'll stop now.
  20. I think the New Zealand T's came from Canada, although I noticed your tub doesn't have an opening driver door like the Canadian bodies. the other complete black one in the picture does. Looks like a good build. Going to follow this one.
  21. Deuced Up!
    Deuced Up!
  22. This body was imported from the USA - I don't know too much about T's so it's all quite new to me so not sure re the metal subframe or wood. I have been repairing the doors and even started to roll up the tube frames for the doors.
    Next up is to finish jigging the body and start on the frame out
  23. hemiboy
    hemiboy
    Make the subframe in steel. Much easier, holds up better and makes door/cowl alignment easier.
  24. Yep exactly - you cant weld wood. :)
  25. Thanks I hope so...
  26. olskool34
    olskool34
    Looking good!
  27. need louvers ?
    need louvers ?
    Yep, and I'm not allergic to metal dust either!!! :D
  28. kiwicowboy
    kiwicowboy
    from linwood nc
    Good looking Greg,seing you guys on here makes me wont to come back home and hang with all you guys like the old days,I will be looking at this .
    It makes me wont to build another one sum day.Trevor..
  29. The more you bolt to these floppy bodies the stronger it becomes - case in point was the screen stanchions.
    Bent some tubing up. The square 1" is for the door posts for hinges and latches to attach to. The small round tube is for the door frames themselves.
    Got the tyres mounted on the wheels and now I can't wait to get them mocked up onto the car!
