History Sneak pipes?? Cheater pipes??
Discussion in 'Traditional Customs' started by Delray292, Feb 20, 2014.
  1. Delray292
    Delray292
    I'm having a brain fart here guys, what do you call those capped exhaust pipes they used to put in the front wheel well poking out just behind the tire?
  2. 40StudeDude
    40StudeDude
    Lakes Plugs...or "dumps"...at least, where I lived that's what we called 'em...
    R-
  3. scrap metal 48
    scrap metal 48
    I use the 2 you mentioned and "cut outs", "lake plugs" and I'm sure there's more...
  4. 55 Ford Gasser
    55 Ford Gasser
  5. slowmotion
    slowmotion
    Peeking out of the wheel well they were called 'lake plugs' around here. 'Cut-outs' were hidden under the car integral to the exhaust system and manually or electrically operated by the driver. That's how I remember it anyways.
  6. Delray292
    Delray292
    Cool, thanks guys!
  7. Lake Plugs in the upper Midwest......Centurion9
  8. V8 Bob
    V8 Bob
    Sneakers or sneak pipes. :cool:
  9. 40StudeDude
    40StudeDude
    Sure, they dumped exhaust out ahead of the muffs...
    Regional areas always had their own words...I grew up in small town Iowa: 'rake' for a nose down at***ude; "spaghetti pipes" for those four foot long chromed, belled scavenger type exhaust pipes hanging below the rear axle; "****ers" for 'J' hooks to pull the coil springs together in the front to achieve a 'rake' and sometimes "dumps" referred to plumber's metal pipe caps welded to the bottom of the exhaust header so you could simply reach under the car and unscrew them. I'm sure there's more that I've forgotten.
    R-
  10. Dumps
  11. Max Gearhead
    Max Gearhead
    from Wisconsin
    x 2
  12. LOL- if I said "I've got a wicked pair of dumps behind my front wheels" with my old buddies back in North Philly, they'd be giggling about the **** someone took on the street by my car :D
  13. slowmotion
    slowmotion
    'Dump' is what you do to the clutch after you uncork you lake plugs...
    Or the next stop after Hector's Burrito Bar...
  14. fat141
    fat141
    Hey Roge, maybe you could write a book on 'em. LOL :):)
    Rod
  15. black 62
    black 62
    from arkansas
  16. I had them on my fuelie 57 Bel Air in the 60's. I simply referred to them as "DUMPS."
  17. Olderchild
    Olderchild
    from Ohio
    Yep- dump the exhaust ,dump the clutch and dump the trany gears all over the street :D been there, done that:eek:
  18. Dumps, Lakers if they ran down the sides.
  19. gnichols
    gnichols
    from Tampa, FL
    Cut-outs or dumps are pretty much the only nick-names I've heard. Gary
  20. sidevalve8ba
    sidevalve8ba
  21. khead47
    khead47
    Dumps around MoTown.
  22. Actually if they were lakes plugs dumping the clutch is the opposite of what you would do. :D
    I have an older friend from indiana (take mine and add nine) that calls them cut outs. I always thought that a cut out was the little Y deally that you could open for straight pipes and close when the cops were comming. But that is what they called them when he was comming up where he came up at.
  23. slowmotion
    slowmotion
    Yep, that's what I mentioned in my earlier post.
    A guy here had a set of lake plugs (dumps to you :D) on a '61 Belair when I was a kid. I thought those things were the coolest thing ever, peeking out of the wheelwell. Tried to talk the old man into putting a set on the family Galaxy. Didn't fly..
  24. i.rant
    i.rant
    I remember them being called Lake pipes or Lake plugs. The guys with the newer Dodges that had the front ends raised used the
    Plumbers pipe plugs in such a way they were hanging almost vertical and could easily be seen when cruising.
    It was an awesome site for a 16 year old driving a 54 Ford in 1963, when they idled through the Dog & Suds intimidating the lesser cars.
    Posted using the Full Custom H.A.M.B. App
  25. 58cchevy
    58cchevy
    back in the 50-60 years we used gas tank necks with caps and called them dumps. the ones on my impala roadster are much better. but they are still dumps.
  26. Iron Dog
    Iron Dog
    from Minnesota
    Way up here in northern Minneeesota. We call them dump tubes. Mine on my 51.
  27. Gman0046
    Gman0046
    Plumbing pipes with ******s that had nuts welded on them was what we called "dumps". Without the nuts they would vibrate off if the ******s weren't tight enough and you couldn't get them off without a wrench if they were too tight. That was the cheap way to go. I always thought the short section of lakes pipe and the chrome looked neat.
  28. scrap metal 48
    scrap metal 48
    here's some gas cap dumps on my coupe.. Easy off and on...
  29. Blue Moon Garage
    Blue Moon Garage
    dumps on my '39 Chevy p/u..................
  30. HOLLYWOOD GRAHAM
    HOLLYWOOD GRAHAM
    from Ojai,Ca
    50’s 60’s So. Cal. was Lakes Pipes if the were capped exhaust pipes that ran parallel on the bottom outside under the door. Cut Outs were usually in the wheel well but many were hidden under the car on the down tube from the exhaust manifold. Those are the only terms I remember them being called. Taking off of the plug was UnCorked. Conversely "Corking Them Back Up was self explanatory. Straight Pipes was no mufflers at all, Duals, Twin or Twice Pipes was two exhaust pipes. Drag Pipes were pipes that ended right under the rear axel. I had my share of loud mufflers, uncorked cut out tickets believe me, especially from Officer Knight. $#@&*#.
