X Frame Chevy sway bar options
Discussion in 'The Hokey Ass Message Board' started by 66galwag, Feb 27, 2014.
  1. 66galwag
    66galwag
    from SoCal
    I have a '60 El Camino and want to put a decent size (about 1") front sway bar on it. I know there are aftermarket parts available but I was wondering if anyone had adapted something from a later model car?
    I was thinking something like a 2nd gen Trans Am or mid 90s Caprice cop car could be a suitable donor.
  2. Danshotrod
    Danshotrod
    My 60 El Camino is fitted with an Nova front clip
  3. Leviman
    Leviman
    Doubt you'd find anything that would be an upgrade. Sway bars are fairly cheap and old cars need bigger bars due to the different roll center heights and centers of gravity.
  4. 38Chevy454
    38Chevy454
    Take measurements of your car and then go to junkyard and see? I've done this for many of my older cars. Just make your measurements with allowable tolerance so you can check several cars at the junkyard.
  5. 66galwag
    66galwag
    from SoCal
    Yeah, that's probably what I'll end up doing, I was just wondering if anyone had already done it.
  6. ROADSTER1927
    ROADSTER1927
    I did on my 60 chevy. If I remember right it was the same bar as on a big block elcamino in 73. It is 1/1/4":D
  7. 66galwag
    66galwag
    from SoCal
    Exactly the kind of thing I was looking for - thanks.
  8. B.A.KING
    B.A.KING
    thanks for that info.........good to know cause my 59,well it kinda leans in the turns.but I forget its not a roadracer;)
  9. partsdawg
    partsdawg
    from Minnesota
    Next question is how many 73 big block el camino's are in junkyards? ;)
