Projects Radius the Rear Fender Wells OR NOT?
Discussion in 'The Hokey Ass Message Board' started by Deuced Up!, Feb 23, 2014.
  1. black 62
    black 62
    from arkansas
    in the day enlarged wheel openings had a lot to do with changing tires for flat towing not looks...
  2. Mike51Merc
    Mike51Merc
    Radiused arches were done to make fat tires fit.
    Yours already fit.
  3. Isn't that a four door? If so, doesn't that mean radiusing would destroy the jamb structure for the back doors?
    Oh, and I like them tucked.
    Steve
  4. Deuced Up!
    Deuced Up!
    It is (was) a four door but it has become a two door with some cool top chopping moves etc. You can see the entire build thread here:
    http://www.jalopyjournal.com/forum/showthread.php?t=859106
    But to answer your question, the actual door jam follows the wheel tub...
  5. Hemi j
    Hemi j
    from Colorado
    Yes !!!!!!!!!!!!
  6. 19blockhead72
    19blockhead72
  7. slammed
    slammed
    radius,, tire hanging out 1"+. Photo shop it without any art, stickers, ect as a blank Shiny black canvas. Those flames are too modern.
  8. chevy57dude
    chevy57dude
  9. T&A Flathead
    T&A Flathead
    IMO: Radiused wheel wells, big fat wheel tubs and big offset wheels don't work together. The entire package needs to be planned out or it will still look like a confused pro "g***er" street
  10. sadsack
    sadsack
    no way sadsack
  11. 33hotrod
    33hotrod
    this to me, is the only way to go! Bad *** look! You can always go with old quarter panel if you had to!!!!!!!!!!!!!!! Just my idea. Ya need to cut!!!!
  12. BamaMav
    BamaMav
    from Berry, AL
    Cut 'em. The dinky wheel well makes the fender look fat . If you ain't gonna cut 'em, put fender skirts on it.:D
  13. Rocky
    Rocky
    Classified Editor
    I'd open 'em up in a heartbeat and let those sidewalls bulge out the sides a little. It's a HOTROD!
  14. stimpy
    stimpy
    for "era correctness" and with Pie crusts , cut them , to me looks wise with a wrinkle wall marshmellow tire I would leave them .
  15. Baumi
    Baumi
    I wouldn´t radius them... as stated before not every g***er back then had straight axles and radiused wheelwells, for practicabilty´s sake it´s probably making sense to cut them open... I´m lazy and I also like them tucked aswell as open, so I´d leave them unradiused.
  16. norcal rizzo
    norcal rizzo
    Id like to vote radius. I think maybe because it takes some of the staunch from the back, itll still be wild either way.
    the metric system? never heard of it.......
  17. el Scotto
    el Scotto
    from Tracy, CA
    Cut it or it's a pro-street car.
  18. 1971BB427
    1971BB427
    from Oregon
    That's true, but show me very many that were nose up with a straight axle that didn't get radiused in the back? This car already has everything, BUT the radius.
  19. Deuced Up!
    Deuced Up!
    Alright the answer is in...(BOTH)! No not one side tuck and the other radius...LOL! I just completed ***embling the rear end and with the wheels bolted up it measure 58" outside tire to outside tire. The factory wheel wells measure 59.75"
    So for now (and to get it on the road etc.) I am going to tuck them because I really like that look BUT since I have 3" studs on the Mosier axles, I can easily put an inch or so spacer behind them at any point and just make it outside the body at which time I will radius the wheel wells as I have always planned!
  20. swade41
    swade41
    from Buffalo,NY
    X-2, I hate the g***er front pro-street rear look, like the car and owner are confused. What it really looks like is a pro-street car owner jumping on the latest fad being "g***er" and jacking up the front with no regards to ascetics. my .02 ...ha ha
  21. Don Moyer
    Don Moyer
    cut cut cut cut.....cut, there did my 5 votes change your mind:D
  22. fiat gasser
    fiat gasser
    My question would be, if you leave the fenders like they are how are you going to get the rear tires off? It does not look like there is enough room to slide the wheel off the studs and still be able to work the tire from behind the fender. I ran into that problem with my car when the rear fenders are on it. I have to remove the rear fender to take the tire off. If you radius them that would solve the problem unless like suggested earlier you make a removeable fender skirt. Just my 2 cents. Awesome build I have been watching it from the start. Good luck.
    Bob
  23. Deuced Up!
    Deuced Up!
    Don't worry, at some point I will Radius them, as that has been the plan from the very beginning. However, with the swooping body line of the Somerset running all the way back through the rear quarters, I really like the tucked look. AND I decided not to call it a "G***er" anymore.
    Since I am not running a Hood and several other issues from the "G***er" rules, I decided to call it a "Compe***ion Coupe". See section four of the 1964 NHRA Rule Book...
    I mean everyone and their brother is building a "G***er" these days. I have not seen anyone building "Compe***ion Coupes"...LOL! Dare to be different!
  24. indianhead74
    indianhead74
    Generally I think that radiused fenders done well are G***er musts, but that little car of yours has such a cool body line carried thru the fender so it probably needs to stay original.
  25. slowmotion
    slowmotion
    Compe***ion Coupe is a whole different animal in most people's eyes.
    But you can sure call it what you like. :D
    Radius, btw.
  26. Deuced Up!
    Deuced Up!
    I know...that was kind of tongue and cheek. Just stirring up trouble...LOL! I thought it was funny (in light of the topic of this thread) that in the rules it actually said I was allowed to run my tires inside the body! LOL
    There is actually an original Austin American (Austin 7) sitting on my show room floor right now...I can't tell you how hard I am fighting taking a torch after it!
  27. Mike VV
    Mike VV
    from SoCal
    Easy, just depends on the "era" you're modeling after..!
    60's, open'em and roll the edges.
    If more modern, leave th eouter fender intact.
    Mike
  28. Larry T
    Larry T
    Maybe not.
  29. captain scarlet
    captain scarlet
    from Detroit
    Radius them and bring the tyres to be just past the openings
    Singlefingerspeedshop.com. Detroit
