Help ID 1960 Pontiac 389
Discussion in 'The Hokey Ass Message Board' started by conncsean, Mar 2, 2014.
  1. conncsean
    conncsean
    I am having a problem finding this engine code anywhere. It is in my '60 Pontiac Ventura 2dr hardtop. I can find all of the different engine option codes, but not this one. Any help would be appreciated! ImageUploadedByH.A.M.B.1393772506.401074.jpg ImageUploadedByH.A.M.B.1393772525.858968.jpg
  2. Closest I can find is a K5 in 61. That's a 257 horsepower 389 with 7.8:1 compression and a 315 hydramatic ******. Whole lotta water over the dam since 1961.
  3. conncsean
    conncsean
    I know. It's weird I can't find a C5 anywhere. The other odd thing on this car is the two tone paint code. It is a CL paint code which seems to be Shelltone Ivory with a Coronado Red roof. I can't find any pics of a 60 Pontiac with that combo. Most seem to have been painted a solid color.
  4. conncsean
    conncsean
  5. Block number is by the distributor hole
    <TABLE cellSpacing=0 cellPadding=0 width=900 border=3 x:str=""> <TBODY> <TR> <TD>C</TD> <TD>B-body</TD> <TD>59</TD> <TD>389</TD> <TD>315</TD> <TD>Powerglide</TD> <TD> </TD> <TD> </TD> <TD>3x2</TD> <TD>532000</TD> <TD>2</TD> <TD> </TD></TR> <TR> <TD>C1</TD> <TD>B-body</TD> <TD>60</TD> <TD>389</TD> <TD>348</TD> <TD>Manual</TD> <TD>425A</TD> <TD> </TD> <TD>3x2</TD> <TD>536387</TD> <TD>2</TD> <TD> </TD></TR> <TR> <TD>C4</TD> <TD>B-body</TD> <TD>60</TD> <TD>389</TD> <TD>318</TD> <TD>3-speed</TD> <TD> </TD> <TD> </TD> <TD>3x2</TD> <TD>536387</TD> <TD>2</TD> <TD>HD tran</TD></TR> <TR> <TD>C4</TD> <TD>B-body</TD> <TD>61</TD> <TD>389</TD> <TD>318</TD> <TD>3-speed</TD> <TD> </TD> <TD> </TD> <TD>3x2</TD> <TD>538181</TD> <TD>2</TD> <TD>HD tran</TD></TR> <TR> <TD>C6</TD> <TD>B-body</TD> <TD>61</TD> <TD>389</TD> <TD>318</TD> <TD>4-speed</TD> <TD> </TD> <TD> </TD> <TD>3x2</TD> <TD>538181</TD> <TD>2</TD> <TD> </TD></TR> <TR> <TD>C8</TD> <TD>B-body</TD> <TD>61</TD> <TD>389</TD> <TD>318</TD> <TD>4-speed</TD> <TD> </TD> <TD> </TD> <TD>3x2</TD> <TD>538181</TD> <TD>2</TD> <TD> </TD></TR></TBODY></TABLE>
  6. conncsean
    conncsean
    Isn't that just date code and casting #? Shouldn't the C5 code be an indicator of the HP, torque, and carburation/2bbl or 4?
  7. Poncho60
    Poncho60
    from N Illinois
    All kinds of 60 Pontiacs had the 2-tone paint scheme......probably the darker bottom was the most common, but I looked at 60 Ventura that had a white body with blue roof.
  8. conncsean
    conncsean
    Cool! Guess I didn't look hard enough!
  9. conncsean
    conncsean
    Another day and more searching. Still no sign of a C5 coded engine.
