1947 Nash 600 ???????
Discussion in 'The Hokey Ass Message Board' started by chopperdaddy007, Jan 13, 2014.
  1. chopperdaddy007
    chopperdaddy007
    from tennessee
    I have a 47 Nash 600 model 4740 car has 38,000 original miles. Runs and purrs like a kitten. Its all original down to the positive ground 6 volt system. I started to redo the wiring and replace the cracked cloth wires with conventional wiring. It has gone well so far. I drove the car about 30 miles yesterday and notice a lot of antifreeze coming out of the over flow tube on the radiator I also noticed it leaking from the water pump. Its raining today so I cant really see what part of the pump its coming from. Also realized the water pump is connect by a shaft to the generator:mad: Question is anyone know where Nash parts are readily available.
  2. 6t5frlane
    6t5frlane
    from New York
    Nashcarclub.org
  3. chopperdaddy007
    chopperdaddy007
    from tennessee
    Thank you 6t5frlane
  4. Skavangs49_Merc
    Skavangs49_Merc
    from Sturgis,SD
    I don't but it is one cool ride.
  5. chopperdaddy007
    chopperdaddy007
    from tennessee
    Ok diagnosis in progress. First I have antifreeze coming out of the over flow tube on the radiator, it doesn't do it at idle only when giving her fuel. Second the shaft that operates the water pump from the generator is leaking where there is a compression fitting, I read in the manual to tighten the nut up while it is operating yeahhhhh right the distributors in the way and you cant reach it from the bottom. I talked to a buddy of mine and he suggested it might be a cracked head gasket. There is no coolant in the oil. The engine runs like a sewing machine no noise what so ever. You cant hardly hear it running and no loss of power. Could this be a thermostat, radiator or radiator cap issue????
  6. gmpenn
    gmpenn
    I had a similar problem with my 47 600 I flushed the system twice then replaced the thermostat also had a friend check the engine with a thermal heat gun for me it solved the problem as far as the water pump goes I had the same problem you can use a plumber's basin wrench it has a flexible head. I tightened it a little at a time without the engine running it was safer also there is a grease filling in the pump
  7. gmpenn
    gmpenn
    here are a bunch of sites I found usefull also try ebay
    PS as far as the Nash car club goes I joined back in August 2013 I found some people are very helpfull and there are also bunch of car snobs, one very respected member told me if he found out my nash was a hot rod and not original he would not sell me any parts even if he had them
    good luck with your car
    http://www.cl***iccardatabase.com/specs.php?series=4629&year=1947&model=27451&view=summary
    http://www.cl***icflatgl***.com/Auto_N_Truck_Manufacturers/Nash/1947_Nash/1947_Nash.htm
    http://www.americanpartsdepot.com/nashindex.htm
    http://www.blaserauto.com/
    http://nashparts.com/parts.htm
    http://www.kanter.com/
    http://www.nashcarclub.org/
    http://www.nashcarclub.org/model/47model.htm
    http://www.nashforums.com/forums/viewtopic.php?f=17&t=5
    http://auto.howstuffworks.com/1941-1948-nash-amb***ador.htm
  8. Hdonlybob
    Hdonlybob
    I had a '47 in high school that was cherry...(got it from my Grandpa)
    Being stupid I messed it all up to attempt to make it cool....
    Keep yours stock, IMO that is a great old car.!
    How about some pictures ?
  9. chopperdaddy007
    chopperdaddy007
    from tennessee
    gmpenn thanks for the info. I took the pump off cleaned it really good regreased it and I bought some graphite packing for sinks and some thick twine. I painstakingly covered the twine in the graphite and made a seal. It worked great lol. She's back on the road now. I appreciate the heads up with the nash club. Thanks for the additional sights. BTW I was google imaging nash's and saw your black on red scheme and it is by far the coolest paint I have seen for one. Hdonlybob, gonna keep her stock except may lowering her a little and new paint shes to nice to cut up. I'll post pics as soon as I figure out how. You can check my profile there are some there.
  10. v8spence
    v8spence
    Sorry for ****ing in but do you (or anyone) have a wiring diagram for the 600 as I am just remaking the loom (existing insulation has cracked off....)
  11. gmpenn
    gmpenn
    Nash wiring
  12. v8spence
    v8spence
    Cheers. :)
    Sent from my GT-I9300 using H.A.M.B. mobile app
  13. Chopper daddy, what part of T.N. are you in? Thanks Bruce.
  14. desotot
    desotot
    Goota love the Hamb.
  15. Stevie Nash
    Stevie Nash
    Yes they are a very tight knit group, but very helpful if you stay on the down low. I also sold some extra parts to them after I hot rodded my Nash! :cool:
