Technical TECH WEEK: Cutting curved laminated glass the cheap and easy way.
Discussion in 'Traditional Customs' started by Morgan91, Feb 22, 2014.
  1. morac41
    morac41
    Hi Morgan 91....Thanks for posting ..have been hangin to see how you cut your screen....are you still useing a two piece or did you install it all in one piece screen..I have several curved screens to practice on...my install is for a 49 Caddy split screen chopped 4 1/2"...have found 70's VW Kombie is nearly the correct curve and I should get the 2 screens out of it..they are pretty cheap so not to expensive if I stuff a couple up.... Doug
  2. 53choptop
    53choptop
  3. fourtogo
    fourtogo
    from long beach
    Auto gl*** guys don't like doing old/used gl***. They will tell you no <!--[if gte mso 9]><xml> <w:WordDo***ent> <w:View>Normal</w:View> <w:Zoom>0</w:Zoom> <w:TrackMoves/> <w:TrackFormatting/> <w:punctuationKerning/> <w:ValidateAgainstSchemas/> <w:SaveIfXMLInvalid>false</w:SaveIfXMLInvalid> <w:IgnoreMixedContent>false</w:IgnoreMixedContent> <w:AlwaysShowPlaceholderText>false</w:AlwaysShowPlaceholderText> <w:DoNotPromoteQF/> <w:LidThemeOther>EN-US</w:LidThemeOther> <w:LidThemeAsian>X-NONE</w:LidThemeAsian> <w:LidThemeComplexScript>X-NONE</w:LidThemeComplexScript> <w:Compatibility> <w:BreakWrappedTables/> <w:SnapToGridInCell/> <w:WrapTextWithPunct/> <w:UseAsianBreakRules/> <w:DontGrowAutofit/> <w:SplitPgBreakAndParaMark/> <w:DontVertAlignCellWithSp/> <w:DontBreakConstrainedForcedTables/> <w:DontVertAlignInTxbx/> <w:Word11KerningPairs/> <w:CachedColBalance/> </w:Compatibility> <w:BrowserLevel>MicrosoftInternetExplorer4</w:BrowserLevel> <m:mathPr> <m:mathFont m:val="Cambria Math"/> <m:brkBin m:val="before"/> <m:brkBinSub m:val="&#45;-"/> <m:smallFrac m:val="off"/> <m:dispDef/> <m:lMargin m:val="0"/> <m:rMargin m:val="0"/> <m:defJc m:val="centerGroup"/> <m:wrapIndent m:val="1440"/> <m:intLim m:val="subSup"/> <m:naryLim m:val="undOvr"/> </m:mathPr></w:WordDo***ent> </xml><![endif]--> guarantees on used gl***. They don't know how it's been handled or abused. If it cracks while chopping it down, it be will I am sorry.
  4. navyboy
    navyboy
    interseting.
  5. chopolds
    chopolds
    from howell, nj
    Actually, I've had MUCH better luck with doing old windshields. The newer, foreign made ones are made of thinner gl***, and often cannot be picked up carelessly after beign chopped. They just break under their own weight. Old ones are stronger, thicker!
    The curvier they are, the harder they are to cut without problems.
  6. Morgan91
    Morgan91
    from Australia
    No worries! Yeah im still running a split windshield at the moment... will eventually try and get a one peice olds one for it.
  7. gas pumper
    gas pumper
    The plastic film that gets cloudy with age from the edges can be from having to put a lot of pressure around the gasket as you work the gl*** into the gasket. It will separate a little and not show up for a while as fogged. So making the gl*** a little undersized helps. Also on curved gl*** sometimes tweeking the metal flange to better suit the gl*** can make getting the gl*** in easier. Pre-fitting the gl*** to the hole and looking for misalignment and consistant gaps can help. A fresh new gasket makes installing easier. Once they get hard and start cracking they are hard to work with.
    I had always cut the plastic with a razor blade and never tried the fire method.
    Painting the edge all around the gl*** helps seal the plastic to the gl*** and keeps moisture from getting in there.
  8. nomadabug
    nomadabug
    I used methyl- hydrate (hardware store) to separate the laminate. It burns much cleaner and is hotter. In fact, if the cut on both sides is in line, the methyl-hydrate (alcohol ) will dissolve the laminate without igniting it.
