I M old style
Discussion in 'New to the H.A.M.B.? Introduce yourself here!' started by I M old style, Feb 28, 2014.
  1. I M old style
    I M old style
    hello I,ve just retired and now have time to build a (hotrod) project that I,ve been wanting to do for years. Ive been working on cars since 11 years of age, have welding ,sheet metal and engine experience. so now I,m looking for ideas for a old style hot rod any help would be greatly appreciated.
  2. Flatheadguy
    Flatheadguy
    Sorry to mention this, but your use of the phrase "rat rod" is most definitely not welcome here. If you had spent a bit of time viewing posts by others then you would know this. Rat rods are **** boxes. If you want to "fit in" here then your need to redo your intro and omit the offending phrase. After doing that, spend a bit time seeing what this site is all about.
    Otherwise, you will be flamed and probably go away.
  3. 55 Ford Gasser
    55 Ford Gasser
    Welcome from Virginia. Good luck with building your hot rod. A lot of traditional hot rods get tagged as rat rods by those that don't understand what's going on. I, myself use to think rat rods were cool because they started out being somewhat traditional but then people got crazy with them. I had a real deal hot rod truck built in 1957 that many would have called a rat rod because they really don't understand. We all hope you go in the right direction with yours. You will find a lot of helpful information here. Ron
  4. ROADSTER1927
    ROADSTER1927
    you are welcome here---building a hot rod-------
  5. I M old style
    I M old style
    didn't want to offend anyone.
  6. 50 Fastback
    50 Fastback
    Welcome from Chicago!
  7. wicarnut
    wicarnut
    Welcome! from northern Wi. Watch the cl***ifieds on here, many interesting projects come up. Just a suggestion, Done driving car for the price of the parts, Check out, lowelife cl***ified, 31A Sedan, NICE! car is priced right. John
  8. navyboy
    navyboy
    you are welcome here---building a hot rod------- x2!
  9. ct1932ford
    ct1932ford
    Welcome from CT!
  10. chop job
    chop job
    from Wisconsin
    Welcome from Palmyra Wi. Hope you find something nice and have a lot of fun dreaming and building your hot rod.
  11. RFH1931
    RFH1931
    Welcome from S.C.
    Good Luck on your project !
  12. crazyblindjoe
    crazyblindjoe
    welcome from pa.. lots of good guys in ohio and wpa. talk to them and they will help you in your search for ideas and possibly a project.:)
