Technical L78-15 coker classic on a Chevy 1951 with stock rims
Discussion in 'Traditional Customs' started by chevythechief, Mar 4, 2014.
  1. chevythechief
    chevythechief
    from Sweden
    Is that gonna work? Is there anyone on the forum that run their Chevy -51 with this setup?
    Thanks in advance 😊
  2. carpok
    carpok
    from Indy
    How wide is your rim. I got a set on 7" rims no problem.
  3. HOTRODPRIMER
    HOTRODPRIMER
    I have them on a 6" rims on the back of my pickup. HRP
  4. desotot
    desotot
    Is that going to be on a pickup truck or a p***enger car /
  5. chevythechief
    chevythechief
    from Sweden
    Sorry guys its a 1951 chevy styleline delux, stock rims.
  6. 54LedSled
    54LedSled
    Dang that's a tall tire!
  7. desotot
    desotot
    Seems a little to tall for a p***enger car.
  8. Have them on my Dodge, on 7 inch wide wheels
  9. 1951Streamliner
    1951Streamliner
    from Reno, NV
    I'd go with Firestone 6.70's
    also, the BF Goodrich 6.70's fit those wheels very well... they have a slightly wider whitewall.
    Both produced by Coker.
    I've had good luck with both.
    Here is a picture of the BF Goodrich 6.70s on a stock Chevy rim.
  10. Hnstray
    Hnstray
    from Quincy, IL
    L-78 is a huge tire for both the stock wheel and proportionate to your car. As I recall, the L-78 was used on full size wagons and large sedans in the late '60s / early '70s.
    I would think an E-78 would be the closest to original dimensions and, if that is the case, an F or G series would be the largest upsize that would be practical. A 6.70 was probably the original size before the letter series tires came to market.
    Of course, that is just my opinion and you may have something very specific in mind you want to achieve. But if you are intent on using an L series, at the very least you should consider a wider rim.
  11. jcmarz
    jcmarz
    from Chino, Ca
    L78s are just too much tire for your car. 6.70-15 is a good size or G78s.
  12. gimpyshotrods
    gimpyshotrods
    Yup, 6.70-15 is the tire for that car.
  13. chevythechief
    chevythechief
    from Sweden
    Yeah that what i thought as well, they will be to big. Just a little bit curious because I have 4 new L78-15 laying in my garage. Thanks for your rime and answers.
    //Pizzton
  14. chevythechief
    chevythechief
    from Sweden
    Time not rime :)
